Hi all,
I've created a new project for my STM32F030, after setting it up, I was able to compile the project, however, after changing the folder for the objects and listings I started getting the following error when compiling:
Fatal error: C3921U: Option '--S' not available with your license.
I tried to revert that change but still shows that error. I've checked the C, ASM and Linker options and I don't see any --S option.
This is my version of Keil uVision.
IDE-Version:µVision V5.32.0.0Copyright (C) 2020 ARM Ltd and ARM Germany GmbH. All rights reserved.
IDE-Version:
µVision V5.32.0.0
License Information:Daniel ManceboLogosLIC=----
Daniel Mancebo
Logos
LIC=----
Tool Version Numbers:Toolchain: MDK-Lite Version: 5.32.0.0Toolchain Path: C:\Keil_v5\ARM\ARMCC\BinC Compiler: Armcc.exe V5.06 update 7 (build 960)Assembler: Armasm.exe V5.06 update 7 (build 960)Linker/Locator: ArmLink.exe V5.06 update 7 (build 960)Library Manager: ArmAr.exe V5.06 update 7 (build 960)Hex Converter: FromElf.exe V5.06 update 7 (build 960)CPU DLL: SARMCM3.DLL V5.32.0.0Dialog DLL: TARMCM1.DLL V1.14.3.0Target DLL: UL2CM3.DLL V1.163.9.0Dialog DLL: TARMCM1.DLL V1.14.3.0
I've searched in the forum and the Keil documentation and I don't see that error code anywhere. Does anyone know what the error is?
Regards,
