Just started to migrate to the ARM compiler 6 and I noticed __weak is incompatible language extension in this version and it needs to be written __attribute__((weak)).
In STM32F4 HAL Drivers and almost all of the ST MCU series, there are lots of functions that have __weak in their declaration while it is not supported in ARM compiler V6. As for ARM Compiler and the DFPs, I have installed the latest versions.
Are we having a problematic kind of situation here?
The HAL is ST's code - so you need to talk to ST about this.
They should document what compilers (and versions) they support.
Shouldn't be hard to get around this with a #define, though ... ?
You're right, I'll contact with them.
As for the solution, I know that there are many ways to get around that. But it's better ST fixes it.
Thanks again.
If ST don't specify that it should work with that compiler, then it isn't really "broken" - you're just using it outside of its specified conditions.
Presumably they will update it in due course ...
