Hello everyone, I'm trying to read the temperature of two LM35 sensors and send them to my phone using HC06 bluetooth module. I've successfully received the temperature of one the sensors on my phone, but when I added the second sensor I received only 0. I checked my circuit connections and tried different adc channels, but still I keep receiving 0 from the second sensor. Interestingly when I use only one adc channel I receive the correct temperature, but when I use 2 adc channels I receive the correct temperature from one sensor and 0 from the other one. Moreover, in debug mode I receive 0 from one of the adc channels, so clearly the problem is with adc and not uart part of the code, I think
Thanks in advance
#include "Hardware.h" #include "lpc17xx_gpio.h" #include "lpc17xx_adc.h" #include "lpc17xx_pinsel.h" #include "lpc17xx_nvic.h" #include "Delay_RIT.h" #include "lpc17xx_uart.h" uint16_t voltage1,voltage2, realTemp1=0,realTemp2=0,localTemp; uint32_t total1=0,total2=0; uint16_t countOfSum1=0,countOfSum2=0; volatile uint8_t flagOfTemp =0; float calcVolt1,calcVolt2; void ADC_IRQHandler() { if(ADC_ChannelGetStatus(LPC_ADC,ADC_CHANNEL_1,ADC_DATA_DONE)==0) { uint16_t temp1; voltage1=ADC_ChannelGetData(LPC_ADC,ADC_CHANNEL_1); calcVolt1=(voltage1*3.48)/4096; temp1=calcVolt1*100; total1+=temp1; countOfSum1++; if (countOfSum1==100) { countOfSum1=0; realTemp1=total1/100; total1=0; flagOfTemp=1; } else ADC_StartCmd(LPC_ADC,ADC_START_NOW); } if(ADC_ChannelGetStatus(LPC_ADC,ADC_CHANNEL_0,ADC_DATA_DONE)==0) { uint16_t temp2; voltage2=ADC_ChannelGetData(LPC_ADC,ADC_CHANNEL_0); calcVolt2=(voltage2*3.48)/4096; temp2=calcVolt2*100; total2+=temp2; countOfSum2++; if (countOfSum2==100) { countOfSum2=0; realTemp2=total2/100; total2=0; flagOfTemp=1; } else ADC_StartCmd(LPC_ADC,ADC_START_NOW); } } uint16_t HW_ADC_Read1() { flagOfTemp=0; ADC_StartCmd(LPC_ADC,ADC_START_NOW); while(flagOfTemp==0); return realTemp1; } uint16_t HW_ADC_Read2() { flagOfTemp=0; ADC_StartCmd(LPC_ADC,ADC_START_NOW); while(flagOfTemp==0); return realTemp2; } void HW_Init() { PINSEL_CFG_Type adcpinsel; PINSEL_CFG_Type uartpinsel; UART_CFG_Type uartConfig; NVIC_SetPriorityGrouping(0x07); adcpinsel.Funcnum=PINSEL_FUNC_1; adcpinsel.OpenDrain=PINSEL_PINMODE_NORMAL; adcpinsel.Pinmode=PINSEL_PINMODE_TRISTATE; adcpinsel.Pinnum=24; adcpinsel.Portnum=0; PINSEL_ConfigPin(&adcpinsel); adcpinsel.Pinnum=23; PINSEL_ConfigPin(&adcpinsel); ADC_Init(LPC_ADC,200000); ADC_IntConfig(LPC_ADC,ADC_ADINTEN1,ENABLE); ADC_IntConfig(LPC_ADC,ADC_ADINTEN0,ENABLE); ADC_ChannelCmd(LPC_ADC,ADC_CHANNEL_1,ENABLE); ADC_ChannelCmd(LPC_ADC,ADC_CHANNEL_0,ENABLE); NVIC_SetPriority(ADC_IRQn,NVIC_EncodePriority(0x07,0,1)); NVIC_EnableIRQ(ADC_IRQn); Delay_RIT_Init(); uartpinsel.Funcnum=PINSEL_FUNC_1; uartpinsel.OpenDrain=PINSEL_PINMODE_NORMAL; uartpinsel.Pinmode=PINSEL_PINMODE_TRISTATE; uartpinsel.Pinnum=2; uartpinsel.Portnum=0; PINSEL_ConfigPin(&uartpinsel); uartpinsel.Pinnum=3; PINSEL_ConfigPin(&uartpinsel); uartConfig.Baud_rate=38400; uartConfig.Databits=UART_DATABIT_8; uartConfig.Parity=UART_PARITY_NONE; uartConfig.Stopbits=UART_STOPBIT_1; UART_Init(LPC_UART0,&uartConfig); UART_TxCmd(LPC_UART0,ENABLE); } //main.c file #include <stdio.h> #include "lpc17xx_gpio.h" #include "lpc17xx_pinsel.h" #include "lpc17XX_uart.h" #include "lpc17XX_adc.h" #include "Hardware.h" #include "Delay_RIT.h" int main() { uint8_t buffstr [20]; HW_Init(); while(1) { uint16_t temp1 = HW_ADC_Read1(); uint16_t temp2 = HW_ADC_Read2(); uint8_t len= sprintf( (char*)buffstr,"%u\n %u\n ",temp1,temp2); UART_Send(LPC_UART0,buffstr,len,NONE_BLOCKING); //send Delay_RIT_ms(1000); } }
