https://github.com/ExploreEmbedded/Explore-Cortex-M3-LPC1768-DVB-14001/blob/master/Code/KeilExamples/00-libfiles/oled_i2c.c
oled library
main
main(){//init_OLED(); SystemInit(); i2c0Init();// OLED_Init(); OLED_Init(P0_19, P0_20); // OLED_SetFont(SmallFont); //OLED_SetFont(2);
while(1) { //OLED_SetFont(MediumNumbers); for(i=0;i<1000;i++) { OLED_PrintFloatNumber(i/3.0,3,50,0); OLED_Update();// delay_ms(1000); } }}
please help i want to print a dtring on oled
Hi rajendra232
I have moved this thread to the Keil forum, where someone will hopefully be able to help you further.
Oli from the Community team
rajendra232 said:please help
Help with what, exactly?
"not working" tells us next to nothing
http://www.catb.org/esr/faqs/smart-questions.html#code
#include <lpc17xx.h> #include <stdint.h> #include "i2c_driver.h" //#include "gpio.h" //#include "stdutils.h" //#include "oled.h" #include <string.h> #define SSD1306_ADDRESS 0x3C #define C_OledLastLine_U8 0x07u #define SSD1306_COMMAND 0x00 #define SSD1306_DATA 0xC0 #define SSD1306_DATA_CONTINUE 0x40 #define SSD1306_SET_CONTRAST_CONTROL 0x81 #define SSD1306_DISPLAY_ALL_ON_RESUME 0xA4 #define SSD1306_DISPLAY_ALL_ON 0xA5 #define SSD1306_NORMAL_DISPLAY 0xA6 #define SSD1306_INVERT_DISPLAY 0xA7 #define SSD1306_DISPLAY_OFF 0xAE #define SSD1306_DISPLAY_ON 0xAF #define SSD1306_NOP 0xE3 #define SSD1306_HORIZONTAL_SCROLL_RIGHT 0x26 #define SSD1306_HORIZONTAL_SCROLL_LEFT 0x27 #define SSD1306_HORIZONTAL_SCROLL_VERTICAL_AND_RIGHT 0x29 #define SSD1306_HORIZONTAL_SCROLL_VERTICAL_AND_LEFT 0x2A #define SSD1306_DEACTIVATE_SCROLL 0x2E #define SSD1306_ACTIVATE_SCROLL 0x2F #define SSD1306_SET_VERTICAL_SCROLL_AREA 0xA3 #define SSD1306_SET_LOWER_COLUMN 0x00 #define SSD1306_SET_HIGHER_COLUMN 0x10 #define SSD1306_MEMORY_ADDR_MODE 0x20 #define SSD1306_SET_COLUMN_ADDR 0x21 #define SSD1306_SET_PAGE_ADDR 0x22 #define SSD1306_SET_START_LINE 0x40 #define SSD1306_SET_SEGMENT_REMAP 0xA0 #define SSD1306_SET_MULTIPLEX_RATIO 0xA8 #define SSD1306_COM_SCAN_DIR_INC 0xC0 #define SSD1306_COM_SCAN_DIR_DEC 0xC8 #define SSD1306_SET_DISPLAY_OFFSET 0xD3 #define SSD1306_SET_COM_PINS 0xDA #define SSD1306_CHARGE_PUMP 0x8D #define SSD1306_SET_DISPLAY_CLOCK_DIV_RATIO 0xD5 #define SSD1306_SET_PRECHARGE_PERIOD 0xD9 #define SSD1306_SET_VCOM_DESELECT 0xDB uint8_t OledLineNum,OledCursorPos; void oledSendCommand(uint8_t cmd) { i2c_start(); i2c_write(0x3C); i2c_write(SSD1306_COMMAND); i2c_write(cmd); i2c_stop(); } void oledSendStart(uint8_t address) { i2c_start(); i2c_write(0x3c); i2c_write(address); i2c_stop(); } void oledSendByte(uint8_t ch) { char i; i2c_start(); i2c_write(SSD1306_ADDRESS); i2c_write(ch); i2c_stop(); } void OLED_Clear() { int i; oledSendCommand(SSD1306_SET_COLUMN_ADDR); oledSendCommand(0); oledSendCommand(127); oledSendCommand(SSD1306_SET_PAGE_ADDR); oledSendCommand(0); oledSendCommand(7); oledSendStart(SSD1306_ADDRESS<<1); oledSendByte(SSD1306_DATA_CONTINUE); for (i=0; i<1024; i++) // Write Zeros to clear the display { oledSendByte(0); } oledSendCommand(SSD1306_SET_COLUMN_ADDR); oledSendCommand(0); oledSendCommand(127); oledSendCommand(SSD1306_SET_PAGE_ADDR); oledSendCommand(0); oledSendCommand(7); oledSendStart(SSD1306_ADDRESS<<1); oledSendByte(SSD1306_DATA_CONTINUE); } void OLED_Init(void) { oledSendCommand(SSD1306_DISPLAY_OFF); oledSendCommand(SSD1306_SET_DISPLAY_CLOCK_DIV_RATIO); oledSendCommand(0x80); oledSendCommand(SSD1306_SET_MULTIPLEX_RATIO); oledSendCommand(0x3F); oledSendCommand(SSD1306_SET_DISPLAY_OFFSET); oledSendCommand(0x0); oledSendCommand(SSD1306_SET_START_LINE | 0x0); oledSendCommand(SSD1306_CHARGE_PUMP); oledSendCommand(0x14); oledSendCommand(SSD1306_MEMORY_ADDR_MODE); oledSendCommand(0x00); oledSendCommand(SSD1306_SET_SEGMENT_REMAP | 0x1); oledSendCommand(SSD1306_COM_SCAN_DIR_DEC); oledSendCommand(SSD1306_SET_COM_PINS); oledSendCommand(0x12); oledSendCommand(SSD1306_SET_CONTRAST_CONTROL); oledSendCommand(0xCF); oledSendCommand(SSD1306_SET_PRECHARGE_PERIOD); oledSendCommand(0xF1); oledSendCommand(SSD1306_SET_VCOM_DESELECT); oledSendCommand(0x40); oledSendCommand(SSD1306_DISPLAY_ALL_ON_RESUME); oledSendCommand(SSD1306_NORMAL_DISPLAY); oledSendCommand(SSD1306_DISPLAY_ON); OLED_Clear(); } void OLED_SetCursor(uint8_t lineNumber,uint8_t cursorPosition) { /* Move the Cursor to specified position only if it is in range */ if((lineNumber <= C_OledLastLine_U8) && (cursorPosition <= 127)) { OledLineNum=lineNumber; /* Save the specified line number */ OledCursorPos=cursorPosition; /* Save the specified cursor position */ oledSendCommand(SSD1306_SET_COLUMN_ADDR); oledSendCommand(cursorPosition); oledSendCommand(127); oledSendCommand(SSD1306_SET_PAGE_ADDR); oledSendCommand(lineNumber); oledSendCommand(7); oledSendStart(SSD1306_ADDRESS<<1); oledSendByte(SSD1306_DATA_CONTINUE); } } #if (Enable_OLED_GoToLine == 1) void OLED_GoToLine(uint8_t lineNumber) { if(lineNumber<8) { /* If the line number is within range then move it to specified line and keep track*/ OledLineNum = lineNumber; OLED_SetCursor(OledLineNum,0); } } #endif void OLED_GoToNextLine() { /*Increment the current line number. In case it exceeds the limit, rool it back to first line */ OledLineNum++; OledLineNum = OledLineNum&0x07; OLED_SetCursor(OledLineNum,0); /* Finally move it to next line */ } #if (Enable_OLED_DisplayLogo == 1) void OLED_DisplayLogo(char *ptr_Logo) { int i; OLED_SetCursor(0,0); oledSendStart(SSD1306_ADDRESS<<1); oledSendByte(SSD1306_DATA_CONTINUE); for ( i=0; i<1024; i++) // Send data { oledSendByte(ptr_Logo[i]); } } #endif #define FONT_SIZE 5 const OledFontTable[][FONT_SIZE]= { 0x00, 0x00, 0x00, 0x00, 0x00, // space 0x00, 0x00, 0x2f, 0x00, 0x00, // ! 0x00, 0x07, 0x00, 0x07, 0x00, // " 0x14, 0x7f, 0x14, 0x7f, 0x14, // # 0x24, 0x2a, 0x7f, 0x2a, 0x12, // $ 0x23, 0x13, 0x08, 0x64, 0x62, // % 0x36, 0x49, 0x55, 0x22, 0x50, // & 0x00, 0x05, 0x03, 0x00, 0x00, // ' 0x00, 0x1c, 0x22, 0x41, 0x00, // ( 0x00, 0x41, 0x22, 0x1c, 0x00, // ) 0x14, 0x08, 0x3E, 0x08, 0x14, // * 0x08, 0x08, 0x3E, 0x08, 0x08, // + 0x00, 0x00, 0xA0, 0x60, 0x00, // , 0x08, 0x08, 0x08, 0x08, 0x08, // - 0x00, 0x60, 0x60, 0x00, 0x00, // . 0x20, 0x10, 0x08, 0x04, 0x02, // / 0x3E, 0x51, 0x49, 0x45, 0x3E, // 0 0x00, 0x42, 0x7F, 0x40, 0x00, // 1 0x42, 0x61, 0x51, 0x49, 0x46, // 2 0x21, 0x41, 0x45, 0x4B, 0x31, // 3 0x18, 0x14, 0x12, 0x7F, 0x10, // 4 0x27, 0x45, 0x45, 0x45, 0x39, // 5 0x3C, 0x4A, 0x49, 0x49, 0x30, // 6 0x01, 0x71, 0x09, 0x05, 0x03, // 7 0x36, 0x49, 0x49, 0x49, 0x36, // 8 0x06, 0x49, 0x49, 0x29, 0x1E, // 9 0x00, 0x36, 0x36, 0x00, 0x00, // : 0x00, 0x56, 0x36, 0x00, 0x00, // ; 0x08, 0x14, 0x22, 0x41, 0x00, // < 0x14, 0x14, 0x14, 0x14, 0x14, // = 0x00, 0x41, 0x22, 0x14, 0x08, // > 0x02, 0x01, 0x51, 0x09, 0x06, // ? 0x32, 0x49, 0x59, 0x51, 0x3E, // @ 0x7C, 0x12, 0x11, 0x12, 0x7C, // A 0x7F, 0x49, 0x49, 0x49, 0x36, // B 0x3E, 0x41, 0x41, 0x41, 0x22, // C 0x7F, 0x41, 0x41, 0x22, 0x1C, // D 0x7F, 0x49, 0x49, 0x49, 0x41, // E 0x7F, 0x09, 0x09, 0x09, 0x01, // F 0x3E, 0x41, 0x49, 0x49, 0x7A, // G 0x7F, 0x08, 0x08, 0x08, 0x7F, // H 0x00, 0x41, 0x7F, 0x41, 0x00, // I 0x20, 0x40, 0x41, 0x3F, 0x01, // J 0x7F, 0x08, 0x14, 0x22, 0x41, // K 0x7F, 0x40, 0x40, 0x40, 0x40, // L 0x7F, 0x02, 0x0C, 0x02, 0x7F, // M 0x7F, 0x04, 0x08, 0x10, 0x7F, // N 0x3E, 0x41, 0x41, 0x41, 0x3E, // O 0x7F, 0x09, 0x09, 0x09, 0x06, // P 0x3E, 0x41, 0x51, 0x21, 0x5E, // Q 0x7F, 0x09, 0x19, 0x29, 0x46, // R 0x46, 0x49, 0x49, 0x49, 0x31, // S 0x01, 0x01, 0x7F, 0x01, 0x01, // T 0x3F, 0x40, 0x40, 0x40, 0x3F, // U 0x1F, 0x20, 0x40, 0x20, 0x1F, // V 0x3F, 0x40, 0x38, 0x40, 0x3F, // W 0x63, 0x14, 0x08, 0x14, 0x63, // X 0x07, 0x08, 0x70, 0x08, 0x07, // Y 0x61, 0x51, 0x49, 0x45, 0x43, // Z 0x00, 0x7F, 0x41, 0x41, 0x00, // [ 0x55, 0xAA, 0x55, 0xAA, 0x55, // Backslash (Checker pattern) 0x00, 0x41, 0x41, 0x7F, 0x00, // ] 0x04, 0x02, 0x01, 0x02, 0x04, // ^ 0x40, 0x40, 0x40, 0x40, 0x40, // _ 0x00, 0x03, 0x05, 0x00, 0x00, // ` 0x20, 0x54, 0x54, 0x54, 0x78, // a 0x7F, 0x48, 0x44, 0x44, 0x38, // b 0x38, 0x44, 0x44, 0x44, 0x20, // c 0x38, 0x44, 0x44, 0x48, 0x7F, // d 0x38, 0x54, 0x54, 0x54, 0x18, // e 0x08, 0x7E, 0x09, 0x01, 0x02, // f 0x18, 0xA4, 0xA4, 0xA4, 0x7C, // g 0x7F, 0x08, 0x04, 0x04, 0x78, // h 0x00, 0x44, 0x7D, 0x40, 0x00, // i 0x40, 0x80, 0x84, 0x7D, 0x00, // j 0x7F, 0x10, 0x28, 0x44, 0x00, // k 0x00, 0x41, 0x7F, 0x40, 0x00, // l 0x7C, 0x04, 0x18, 0x04, 0x78, // m 0x7C, 0x08, 0x04, 0x04, 0x78, // n 0x38, 0x44, 0x44, 0x44, 0x38, // o 0xFC, 0x24, 0x24, 0x24, 0x18, // p 0x18, 0x24, 0x24, 0x18, 0xFC, // q 0x7C, 0x08, 0x04, 0x04, 0x08, // r 0x48, 0x54, 0x54, 0x54, 0x20, // s 0x04, 0x3F, 0x44, 0x40, 0x20, // t 0x3C, 0x40, 0x40, 0x20, 0x7C, // u 0x1C, 0x20, 0x40, 0x20, 0x1C, // v 0x3C, 0x40, 0x30, 0x40, 0x3C, // w 0x44, 0x28, 0x10, 0x28, 0x44, // x 0x1C, 0xA0, 0xA0, 0xA0, 0x7C, // y 0x44, 0x64, 0x54, 0x4C, 0x44, // z 0x00, 0x10, 0x7C, 0x82, 0x00, // { 0x00, 0x00, 0xFF, 0x00, 0x00, // | 0x00, 0x82, 0x7C, 0x10, 0x00, // } 0x00, 0x06, 0x09, 0x09, 0x06 // ~ (Degrees) }; void OLED_DisplayChar(uint8_t ch) { uint8_t dat,i=0; if(((OledCursorPos+FONT_SIZE)>=128) || (ch=='\n')) { /* If the cursor has reached to end of line on page1 OR NewLine command is issued Then Move the cursor to next line */ OLED_GoToNextLine(); } if(ch!='\n') /* TODO */ { ch = ch-0x20; // As the lookup table starts from Space(0x20) while(1) { dat= OledFontTable[ch][i]; /* Get the data to be displayed for LookUptable*/ oledSendByte(dat); /* Display the data and keep track of cursor */ OledCursorPos++; i++; if(i==FONT_SIZE) /* Exit the loop if End of char is encountered */ { oledSendByte(0x00); /* Display the data and keep track of cursor */ OledCursorPos++; break; } } } } void OLED_DisplayString(uint8_t *ptr) { while(*ptr) OLED_DisplayChar(*ptr++); } main() { i2c0Init(); // i2c int // OLED_Init(); // oled init// OLED_SetCursor(2,0); OLED_DisplayString("Agam"); OLED_SetCursor(4,20); OLED_DisplayString("panday"); while(1) { //TODO:: Please write your application code } }
void i2c0Init(void) { LPC_SC->PCONP |= (1 << 19); // power clok to the i2c0 //LPC_PINCON->PINSEL1 &= ~((0x03<<22) | (0x03<<24)); // clearing the bits LPC_PINCON->PINSEL0 |= 0x0000000F ; // enable the scl,sdl 1 //my i2c intial// LPC_SC->PCLKSEL0 |= 0x00004000; // clock /2 LPC_I2C1->I2SCLH = 128; // LPC_I2C1->I2SCLL = 128; // //NVIC_EnableIRQ(I2C0_IRQn); } void i2c_start() { LPC_I2C1->I2CONCLR = 0x000000FF; // Clear all I2C settings LPC_I2C1->I2CONSET = (1<< I2EN); // Enable the I2C interface LPC_I2C1->I2CONSET = (1<< STA); // Start condition while(LPC_I2C1->I2STAT != 0x08); // wait until A START condition has been transmitted. } void i2c_stop(void) { unsigned int status; LPC_I2C1->I2CONCLR = (1<<STA); // START flag Clear bit. LPC_I2C1->I2CONCLR = (1<<SI); // I2C interrupt Clear bit. LPC_I2C1->I2CONCLR = (1<<AA); // ACK flag Clear bit. LPC_I2C1->I2CONSET = (1<<STO); // STOP flag. } void i2c_write(unsigned char data) { unsigned int status; LPC_I2C1->I2DAT = data; // This register holds contents of the 8 MSBs of the I2DAT shift register. LPC_I2C1->I2CONCLR = (1<<STA); LPC_I2C1->I2CONCLR = (1<<AA); // ACK flag Clear bit. LPC_I2C1->I2CONCLR = (1<<SI); // I2C interrupt Clear bit. //while(LPC_I2C0->I2STAT != 0x28); // Data byte in I2DAT has been transmitted; ACK has been received. while(!((status=LPC_I2C1->I2CONSET)& (1<<SI))); } unsigned char I2Cget(void) { unsigned char data; unsigned int status; LPC_I2C1->I2CONCLR = (1<<STA); LPC_I2C1->I2CONCLR = (1<<STO); LPC_I2C1->I2CONCLR = (1<<SI); LPC_I2C1->I2CONSET = (1<<AA); // send ack to continue further data transfer while(!((status=LPC_I2C1->I2CONSET)& (1<<SI))); //wait till interrupt flag becomes set data = LPC_I2C1->I2DAT ; return data; }
tank you for little guidance this is my code ,when i use simulation debug it is struck in system init()> clock section ,
when i comment all the functions except 12cinit(); iam sendind some dummy data to sdl line i can see in c.r.o .
please help me
