Hello everybody,
I am using Keil microvision IDE (EVALUATION copy) for my project testing. I am burning hex file through flash magic software using ISP mode.
Initially i wrote simple serial port (uart0) example code.Also added few lines to toggle LED connected to pin P1.24.
Now when i compiled code in Microvision V5 (keil MDK), its serial message showing in my PC hyper terminal. Bit LED (related port pin) state not changed to show blinking.
Hence i copy code & compiled in Microvision Keil 4 IDE, But there nither serial messaging nor led blinking happened.
when i retested same in Keil MDK again serail message shows but not LED, why so ?
I tested all parameters well again & again ( FOSC,CCLK,PCLK settings, UART0 & port settings). All are correct.
Anybody has any idea whether my controller is not executing well?
have some found similar issue?
/* Author:- Embedded Laboratory FOSC = 10MHz CCLK = 60MHz PCLK = 15MHz */ #include <LPC213X.H> void initClocks(void); void initGPIO(void); void toggle_led(void); void delay_100ms(unsigned char ii); #define REL_EN (0x01<<22) //p0.22 #define LED1 (0x01<<24) //p1.24 //#define LED2 (0x01<<26) //p1.26 char String[]="Welcome to LPC!!! \n\r\n"; unsigned int delay; /*********************************************/ /**************Function Prototypes************/ void UART0_Init(void); void UART0_Write(unsigned char value); void UART0_Write_Text(unsigned char msg[]); unsigned char UART0_Read(void); /*********************************************/ unsigned char msg[] = "Embedded Laboratory\r\n"; unsigned char echo_test[] = "Echo Test\r\n"; int main() { initClocks(); initGPIO(); UART0_Init(); UART0_Write_Text(msg); UART0_Write_Text(echo_test); while(1) { toggle_led(); UART0_Write(UART0_Read()); } } /****************Function Definition**********/ void initClocks(void) { PLLCON = 0x01; //Enable PLL //PLLCFG = 0x24; //Multiplier and divider setup //12mhz crystal PLLCFG = 0x25; //Multiplier and divider setup //10mhz crystal PLLFEED = 0xAA; //Feed sequence PLLFEED = 0x55; while(!(PLLSTAT & 0x00000400)); //is locked? PLLCON = 0x03; //Connect PLL after PLL is locked PLLFEED = 0xAA; //Feed sequence PLLFEED = 0x55; // VPBDIV = 0x01; // PCLK is same as CCLK i.e.60 MHz VPBDIV = 0x00; // PCLK =15mhz is same as 1/4th of CCLK i.e.60 MHz } /***************UART-0 Functions**************/ void UART0_Init(void) { PINSEL0 = 0x00000005; //P0.0 as TX0 and P0.1 as RX0 U0LCR = 0x83; //Enable access to Divisor Latches //and Set 8 bit Character Length with 1 Stop bit and Parity Disabled //Access to Divisor Latches is Enabled, in order to write Baud Rate Generator Registers //Values to be written in Baud Rate Registers U0DLM and U0LL /* Formula is Baud_Rate = PCLK*MulVal / [(16*(256*U0DLM+U0DLL)*(MulVal + DivAddVal))] Example:- MulVal = 1; DivAddVal = 0; Baud_Rate = 9600; PCLK = 15MHz U0DLM = 0; Hence, U0DLL = 15000000/(9600*16) = 97.65625 = 98 U0DLL = 98 = 0x62 */ U0DLM = 0x00; U0DLL = 0x62; //Baud Rate of 9600 U0LCR = 0x03; //Disable Access to Divisor Latches } void toggle_led(void) { IOCLR1 = LED1; //IOCLR1 = LED2; delay_100ms(10); IOSET1 = LED1; //IOSET1 = LED2; delay_100ms(10); } //delay of 100 msec void delay_100ms(unsigned char ii) { unsigned i,j; i = 648117; j = i * ii; for(i=0;i<=j;i++) { ii = 0; } } void initGPIO(void) { PINSEL1 = 0x00000000; PINSEL2 = 0x00000000; IODIR0 = 0xFFFFFFFC; IODIR1 = 0xFFFF0000; } void UART0_Write(unsigned char value) { /* THRE bit can be extracted by this U0LSR & 0x20 THRE = 0 means data is present. THRE = 1 means register is empty. In order to transmit data, we have to wait will the THRE = 1, then only we can transmit data. */ while(!(U0LSR&0x20)); //THRE = 0 stay here U0THR = value; } void UART0_Write_Text(unsigned char msg[]) { while(*msg) { UART0_Write(*msg); msg++; } } unsigned char UART0_Read(void) { /* Receiver Data Ready = U0LSR.0 bit RDR bit can be extracted by this U0LSR & 0x01 RDR = 0 means no Data is Received in U0RBR RDR = 1 means that Data is present in U0RBR */ while(!(U0LSR & 0x01)); //RDR = 0 stay here return (U0RBR); } /*********************************************/
Note, since MDK 5.30 Arm7/Arm9 support requires to use Keil MDK Professional or MDK Keil Essential
http://www2.keil.com/mdk5/selector
https://www.keil.com/support/docs/4230.htm
