I could use some help getting an SD card up and running on TWR-K60F120M. I've been having a difficult time locating resources on the proper way to initialize this "module". I have enabled a memory card via the "Run-Time Environment" feature in Keil. The issue I'm now having is that finit("M0:") hangs but fmount("M0:") does not. Could someone please let me know the appropriate way of initializing the file system?
Below is an empty project I'm using to test with:
#include <stdio.h> #include "rl_fs.h" #include "cmsis_os2.h" #include "system_MK60F12.h" volatile int test = 0; int main (void) { SystemInit(); //osKernelInitialize (); volatile fsStatus test2 = finit ("M0:"); //volatile fsStatus test3 = fmount ("M0:"); //volatile fsStatus test2 = finit (""); while(1) { if(test > 500) { test = 0; } } return 0; } void Driver_SPI0(void) { }
Here is the configuration:
FileSystem (Middleware) support is offered by MDK, but it is required to order a License Key (PSN)
www2.keil.com/.../middleware
http://www2.keil.com/mdk5
http://www.keil.com/distis/
Registered customers get entitled open a corresponding Keil Support Request:
www2.keil.com/.../silver
