Since the update to MDK5.32, the step over button during debug behaves just as e free run command. I noticed this unexpected behaviour using compiler 6.14.1 or 6.13.1, whereas if I use compiler 5 the step over works properly.
Thank you
Best regards
You're sure this isn't just an optimisation issue ?
No, I use default or -O0
Can you please open a Keil Support Ticket according to:
http://www2.keil.com/support/silver
Ok, case opened. Thanks
