I'm currently using CMSIS 5.7.0 with ARM compiler 5.I noticed that there are 2 locations where HEAP, STACK size are defined.files are located in CMSIS 5.7.0 directory: ARM.CMSIS.5.7.0/Device/_Template_Vendor/Vendor/Device/Source/ARM
In the scatter file, it defines STACK/HEAP size and it's placement defined as ARM_LIB_HEAP and ARM_LIB_STACK.
/*--------------------- Stack / Heap Configuration --------------------------- ; <h> Stack / Heap Configuration ; <o0> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8> ; <o1> Heap Size (in Bytes) <0x0-0xFFFFFFFF:8> ; </h> *----------------------------------------------------------------------------*/ #define __STACK_SIZE 0x00000200 #define __HEAP_SIZE 0x00000C00 . . . LR_ROM __RO_BASE __RO_SIZE { ; load region size_region ER_ROM __RO_BASE __RO_SIZE { ; load address = execution address *.o (RESET, +First) *(InRoot$$Sections) .ANY (+RO) .ANY (+XO) } RW_RAM __RW_BASE __RW_SIZE { ; RW data .ANY (+RW +ZI) } #if __HEAP_SIZE > 0 ARM_LIB_HEAP __HEAP_BASE EMPTY __HEAP_SIZE { ; Reserve empty region for heap } #endif ARM_LIB_STACK __STACK_TOP EMPTY -__STACK_SIZE { ; Reserve empty region for stack } }
In the assembly startup file, it also defines STACK/HEAP size as below.
;<h> Stack Configuration ; <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8> ;</h> Stack_Size EQU 0x00000400 AREA STACK, NOINIT, READWRITE, ALIGN=3 __stack_limit Stack_Mem SPACE Stack_Size __initial_sp ;<h> Heap Configuration ; <o> Heap Size (in Bytes) <0x0-0xFFFFFFFF:8> ;</h> Heap_Size EQU 0x00000C00 IF Heap_Size != 0 ; Heap is provided AREA HEAP, NOINIT, READWRITE, ALIGN=3 __heap_base Heap_Mem SPACE Heap_Size __heap_limit ENDIF PRESERVE8 THUMB
I find this troublesome since if I have to modify both files at the same time.
Is there a reason for this?
I have also noticed the corresponding new startup_Device.c does not redefine stack/heap size like in the assembly startup file.
Thanks ahead for the help!
The mentioned assembly startup is based on the older approach where startup was standalone and STACK/HEAP was configured within the startup file rather than with the linker scatter file. This is being deprecated.
The newer “C Startup” variant includes the C startup combined with linker scatter file that configures STACK/HEAP. The new scatter file should only be used together with the C startup and is not needed when using the legacy assembly startup.
Thanks for the reply, I will use the new C startup file from now on.
