hello, good morning everybody! i have some doubts about this, i'm using an ATMEL SAMD2 microcontroller, i'm new to this compiler and they let me handle this micro in keil uvision. I tried to make a library handling C++ language but I get these errors and this is the code:
I hope you can see the screenshots I captured, otherwise I leave the errors that marked me the compiler:
Build started: Project: Puerto 1*** Using Compiler 'V6.14', folder: 'C:\Keil_v5\ARM\ARMCLANG\Bin'Build target 'Target 1'prueba.cpp(3): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include\samd21.h(54): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/samd21g18a.h(241): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/ac.h(226): error: anonymous bit-field cannot have qualifiers __I uint8_t :2; /*!< bit: 2.. 3 Reserved */ ^C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/ac.h(228): error: anonymous bit-field cannot have qualifiers __I uint8_t :3; /*!< bit: 5.. 7 Reserved */ ^C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/ac.h(232): error: anonymous bit-field cannot have qualifiers __I uint8_t :2; /*!< bit: 2.. 3 Reserved */ ^C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/ac.h(234): error: anonymous bit-field cannot have qualifiers __I uint8_t :3; /*!< bit: 5.. 7 Reserved */ ^prueba.cpp(3): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include\samd21.h(54): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/samd21g18a.h(242): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/adc.h(480): error: anonymous bit-field cannot have qualifiers __I uint8_t :4; /*!< bit: 4.. 7 Reserved */ ^prueba.cpp(3): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include\samd21.h(54): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/samd21g18a.h(243): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/dac.h(181): error: anonymous bit-field cannot have qualifiers __I uint8_t :5; /*!< bit: 3.. 7 Reserved */ ^prueba.cpp(3): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include\samd21.h(54): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/samd21g18a.h(244): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/dmac.h(826): error: anonymous bit-field cannot have qualifiers __I uint8_t :5; /*!< bit: 3.. 7 Reserved */ ^prueba.cpp(3): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include\samd21.h(54): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/samd21g18a.h(246): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/eic.h(362): error: anonymous bit-field cannot have qualifiers __I uint32_t :16; /*!< bit: 16..31 Reserved */ ^C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/eic.h(366): error: anonymous bit-field cannot have qualifiers __I uint32_t :16; /*!< bit: 16..31 Reserved */ ^prueba.cpp(3): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include\samd21.h(54): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/samd21g18a.h(247): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/evsys.h(488): error: anonymous bit-field cannot have qualifiers __I uint32_t :4; /*!< bit: 20..23 Reserved */ ^C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/evsys.h(493): error: anonymous bit-field cannot have qualifiers __I uint32_t :4; /*!< bit: 28..31 Reserved */ ^C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/evsys.h(499): error: anonymous bit-field cannot have qualifiers __I uint32_t :4; /*!< bit: 20..23 Reserved */ ^C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/evsys.h(501): error: anonymous bit-field cannot have qualifiers __I uint32_t :4; /*!< bit: 28..31 Reserved */ ^prueba.cpp(3): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include\samd21.h(54): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/samd21g18a.h(250): warning: In file included from...C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/i2s.h(316): error: anonymous bit-field cannot have qualifiers __I uint16_t :2; /*!< bit: 2.. 3 Reserved */ ^C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/i2s.h(319): error: anonymous bit-field cannot have qualifiers __I uint16_t :2; /*!< bit: 6.. 7 Reserved */ ^C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/i2s.h(322): error: anonymous bit-field cannot have qualifiers __I uint16_t :2; /*!< bit: 10..11 Reserved */ ^C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/i2s.h(325): error: anonymous bit-field cannot have qualifiers __I uint16_t :2; /*!< bit: 14..15 Reserved */ ^C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/i2s.h(329): error: anonymous bit-field cannot have qualifiers __I uint16_t :2; /*!< bit: 2.. 3 Reserved */ ^C:/Users/uriel/AppData/Local/Arm/Packs/Keil/SAMD21_DFP/1.3.0/Device/SAMD21A/Include/component/i2s.h(331): error: anonymous bit-field cannot have qualifiers __I uint16_t :2; /*!< bit: 6.. 7 Reserved */ ^fatal error: too many errors emitted, stopping now [-ferror-limit=]20 errors generated.compiling prueba.cpp...".\Objects\Puerto 1.axf" - 19 Error(s), 0 Warning(s).Target not created.Build Time Elapsed: 00:00:01
I want to know if the microcontrollers of the ATMEL(Microchip) family support C++ language programming on keil uvision or do I have to use their ATMEL STUDIOS interface?
I hit this recently, too (on the SAMC21). ARMCLANG is built from Clang (naturally), and Clang addresses C++ DR2229 (see the list of C++ defects here). I'm not aware of a clang switch that can turn off the DR2229 fix.
The solution I chose was to use C for the functionality that needed access to the things defined in samc21.h, and call those functions from my C++ code.
Hello, Adam Lins! Thank you, I reviewed the document, so you don't add the SAMC21 library as such? or what do you call it? I didn't quite understand the solution.
I'm using the SAMC21 libraries -- I just don't include the SAMC21 header file in any C++ files, to avoid the compiler complaining about the header. I define functions in C files that use the information from the header (e.g., timer register access structures), and call those "helper" functions from the C++ code.
C++ is not a proper superset of C - there are a few things that are allowed in 'C', but not in C++.
"anonymous bit-fields with qualifiers" would be one of them ...
So 'C' code which relies upon such things cannot just be compiled as C++
Similar issues exist with some of Nordic's SDK code.
