Which timer is the best choice for RTX RTOS?
I have found a variety of timers and wonder which one I should use for my RTOS application. I should run a non-timing-critical task periodically. I found the GPIO timers on the Cortex M3 as well as the SysTick timers. Then there is also a virtual timer that is offered by the RTOS itself and described under Timer Management.
My assumptions are:
  • GPIO Timers are best for timing critical applications but can't be configured via CMSIS
  • SysTick is a standardized timer from ARM, which is the same on all Cortex-M processors and thus easily configurable via CMSIS. It works with ticks and thus the best choice for an RTOS
  • Virtual timers are thread-based and probably waste the most processor resources, because they are not hardware-based but provided by the RTOS.
Then there is also the question about the interrupt. The ISR should just check connections every few seconds. There are NVIC Interrupts and I could just define a function in the SysTick handler. My application already uses a UART callback interrupt that should definitely have the highest priority.
  • So I basically answered a few of the functions myself. Since I am using the RTX Kernel the SysTick Timer is used by the Virtual Timer of the RTOS. I can't define SysTick_Handler, because it is already defined in irq_cm3.s. I think for simple non-timing-critical task this Timer is a better choice than the GPIO Timers. I also don't need NVIC Interrupts for this, because from what I have understood they are mostly for triggering interrupts by periphals, which I don't need.
  • How long does the task take to complete? If it could a long time (relative to your application's needs), it's probably better to run as a thread. You can use osThreadFlagsWait() to block on signals with an arbitrary timeout (in RTOS ticks).
  • Sorry for the late reply. It doesn't take long. It should just check if the devices on the serial ports are still connected. It is also not time critical. I am now using the Virtual Timer and it works. I will keep your suggestion in mind though.
