Are you expected to manually set registers in Keil µVision?
In the university we had to programm all registers manually. You were only given the header file for the device with all of the registers. From what I have understood Keil acts like an interface to set registers via the CMSIS files. Still some registers are not available in the RTE_Device.h or system.c
So are you expected to set registers manually or not? Does it depend on the device? This is really confusing
For example:
There is the Periphals Menu where you can set all registers while debugging, but I don't see a menu where I can set this before debugging. If I have to set this manually, it is okay, but then I don't know why you can set some registers and not all of them.
I want to configure the hardware timer of the LPC1769. Usually you would set the registers manually. How does Keil access this register? Via the SysTick Timer configuration?
  • LPC17xx.h is the header file with all the registers.
  • I think I was just a little confused with the different timers. I now found out that the SysTick timer is an ARM specific timer and probably the best choice to use in an RTOS. The GPIO timers differ from processor to processor from what I have read and thus it is probably hard to control them via CMSIS.
    Nevertheless two of the GPIO timers are activated. Do you know if the RTOS uses them for its own functionality. They are not configured in the code (didn't write it), so I wonder why they are active.
