I am trying to create a timer and start it according to the guide.
// Create timers osTimerId_t UART_timer = osTimerNew(printMessage, osTimerPeriodic, (void *) 5U, NULL); if (UART_timer != NULL) printf("Periodic UART timer created\n"); else printf("Periodic UART timer could not be created started\n"); osStatus_t timerStatus = osTimerStart(UART_timer, 5U); if(timerStatus == osOK) printf("Periodic UART timer has been started\n"); else printf("Periodic UART timer could not be started: Error %d\n", timerStatus);
void printMessage(void *arg) { int32_t time = (int32_t) arg; printf("Timer has executed after %d seconds\n", time); }
I create the timer after the kernel initialization as described and then start it. I can't figure out why it doesn't work. I did it exactly as described. The return value is osErrorResource, but the timer was created successfuly.
On further inspection this if statement fails. So obviously the ticks are not specified, although I put the arguments in the function.
if (osRtxInfo.timer.tick == NULL) { EvrRtxTimerError(timer, (int32_t)osErrorResource); //lint -e{904} "Return statement before end of function" [MISRA Note 1] return osErrorResource;
Could it be related to this?
github.com/.../1b483a0202e24844da8bd6a8dc5b7830908c961a
Yes, that certainly explains it.
You may create a timer after KernelInitialize but you may not Start a timer until the Kernel is Started. (There is not timer thread nor is the Systick running)
