Hi all,
I am using infenion TLE9877 controller. My controller is working in debug mode and after flash only once. If i uncheck "Reset and run" check in flash then it does not work for single time also after flash.
Please provide me solution what is happening after power reset or normal reset.
After power cycle or reset controller does not start
Is your hardware providing a proper RESET signal to the chip at startup?
Does your hardware design meet the power-up requirements specified in the manufacturer's documentation for the chip?
https://www.infineon.com/cms/en/product/microcontroller/embedded-power-ics-system-on-chip-/3-phase-bridge-driver-integrated-arm-cortex-m3/tle9877qxa40/
