Hi;
I want to creat a project by using UV4 MyProject.uvprojx –i keil.xml,
Then i make a xml file. keil.xml <?xml version="1.0"?> <Project xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="project_import.xsd"> <Device>em357</Device> <IncludePath>E:\NUC472_442\SampleCode</IncludePath> <Groups> <Group> <GroupName>bcca</GroupName> <Files> <FileName>bcca_sdk</FileName> <FileType>.c</FileType> <FilePath>E:\NUC472_442\file</FilePath> </Files> </Group> <Group> <GroupName>emlib</GroupName> </Group> </Groups> </Project> , and i execute the command, but the xml file don't work, i don't know why? I don't know the xml knowlege much.
Best regards
peng
