Actually I read from the Mastering in the FreeRTOS documentation that,
/* If all is well then main() will never reach here as the scheduler will now be running the tasks. If main() does reach here then it is likely that there was insufficient heap memory available for the idle task to be created. Chapter 2 provides more information on heap memory management. */ for( ;; );
what if I removed for( ;; ); from the main? I mean in case if anything happens in the project and if the control goes to that infinite loop then the product will hang forever.
So my question is why we use this?? can we remove it??
missing the required endless loop I expect that your program terminates within a sys_exit() (or similar) call
That's actually the wrong question. Where exactly do you expect your program to go after it fell off the end of main()? And how do you expect that result to be in any way, shape or form better than to be stuck in a well-defined endless loop?
Okay Thank you sir.
lets say if we have code
void main(void) { }
at the end contains a return statement although we didn't explicitly put it there ourselves. When main returns the CPU executes the next instruction which is simply a GOTO to go back to the beginning of the code. main() is simply called over and over again. So why we preffer to stuck in while loop (at the end of the main) rather than calling main function again and again.
Sir please can you elaborate what you are saying. I really want to clear this concept in my mind.
omkardixi said:When main returns the CPU executes the next instruction which is simply a GOTO to go back to the beginning of the code.
Do you just assume that happens, or did you look it up in some documentation about this tool chain?
I got the answer on the FreeRTOS forum
What happens when you exit an embedded program is only defined by a particular implementation. Some may restart the program, but many just loop to stall. In any case, your program had a major failure where the system didn’t start up, and retrying is unlikely to change that. Ideally you want it easy to see what happened when debugging, so having the loop right there is helpfull.
