JTAG connector preference - ARM 20 vs. ARM 10
I have several products that use the standard ARM 20 pin JTAG programming connector.  I decided to investigate downsizing to the ARM 10 pin to save a little space on a new project.  It works, but most of my JTAG programmers do not have the 10 pin ARM connector option inside the casing.  A few do.  So, is the 10 pin not really used much?  Should I not use it?  Should I just stay with the common 20 pin I've used for years?  Looking for input.  Thanks.  I also noticed the 20 pin to 10 pin adapters have been discontinued, so that might be a hint as well.
