I am a newbee to MDK Keil and am trying to run my 1st project in uVision 5 in simulation mode for stm32f103c8. However, target is not created while building the project. Also the header file shows an error but I am not able to make any changes (for target device) as the header file is locked and cannot be edited.
Any help is appriciated.
The error is displayed as:
Build started: Project: f*** Using Compiler '', folder: 'C:\Users\Hardik Nagar\Desktop\MDK_lite\Keil_v5\ARM\ARMCLANG\bin\'Build target 'Stm32f103c8_test1'compiling test_blinky.c...*** Error: CreateProcess failed, Command: '"C:\Users\Hardik Nagar\Desktop\MDK_lite\Keil_v5\ARM\ARMCLANG\bin\\ArmCC" --via ".\objects\test_blinky.__i"'assembling startup_stm32f10x_md.s...*** Error: CreateProcess failed, Command: '"C:\Users\Hardik Nagar\Desktop\MDK_lite\Keil_v5\ARM\ARMCLANG\bin\\ArmAsm" --via ".\objects\startup_stm32f10x_md._ia"'compiling system_stm32f10x.c...*** Error: CreateProcess failed, Command: '"C:\Users\Hardik Nagar\Desktop\MDK_lite\Keil_v5\ARM\ARMCLANG\bin\\ArmCC" --via ".\objects\system_stm32f10x.__i"'linking...--- Error: failed to execute 'C:\Users\Hardik Nagar\Desktop\MDK_lite\Keil_v5\ARM\ARMCLANG\bin\ArmLink'".\Objects\f.axf" - 1 Error(s), 0 Warning(s).Target not created.Build Time Elapsed: 00:00:00
The header file shows error (cross 'X' mark in the line) in:
#if !defined (STM32F10X_LD) && !defined (STM32F10X_LD_VL) && !defined (STM32F10X_MD) && !defined (STM32F10X_MD_VL) && !defined (STM32F10X_HD) && !defined (STM32F10X_HD_VL) && !defined (STM32F10X_XL) && !defined (STM32F10X_CL) #error "Please select first the target STM32F10x device used in your application (in stm32f10x.h file)"#endif
Thank you
Do not install Keil into a folder with blanks in its path name. That routinely breaks things in strange ways.
There are many examples for STM32F103 in Pack Installer. It's better to take reference from these examples before hand.
