Hello, I've just started with Arm Assembly and downloaded Keil but I'm not sure how do I debug the below "Hello World" program, When I create a new project what device should I select? I know it might be a dumb question but I'm stuck at the moment. Thank you
.data /* Data segment: define our message string and calculate its length. */ msg: .ascii "Hello, ARM!\n" len = . - msg .text /* Our application's entry point. */ .globl _start _start: /* syscall write(int fd, const void *buf, size_t count) */ mov %r0, $1 /* fd := STDOUT_FILENO */ ldr %r1, =msg /* buf := msg */ ldr %r2, =len /* count := len */ mov %r7, $4 /* write is syscall #4 */ swi $0 /* invoke syscall */ /* syscall exit(int status) */ mov %r0, $0 /* status := 0 */ mov %r7, $1 /* exit is syscall #1 */ swi $0 /* invoke syscall */
The recommended way to start with Keil's PK51 is explained at:
https://www.keil.com/product/brochures/uv4.pdf
In example page 35 explains the Debugger.
( access to PK51: https://www.keil.com/c51/pk51kit.asp )
