Hi I have downloaded keil uvision5 and in package istaller when i tried to install a package for stm32f103 series or any other part series cannot download URL (connection interrupted) appears and the package is not installed i have tried the solution from the forum link https://www.keil.com/support/docs/4199.htm but no results the registry values are same as said in the forum. The os im using is windows 7 32 bit kindly help me out...
thankyou
You can try the Pack Installer of the latest MDK v5.31.
Alternatively you can manually download packs from this URL https://www.keil.com/dd2/pack/
thankyou.
ChenTang said:Alternatively you can manually download packs from this URL https://www.keil.com/dd2/pack
yes im downloading it mannually at present.
ChenTang said:You can try the Pack Installer of the latest MDK v5.31
im also having the mdkv5.31 and pack installer version 1.3.98.0 even though i cannot downlod pack installer
