#include <reg51.h>#define DATA P0;void lcd_init(void);void lcd_cmd(unsigned char);void key_scan (void);void delay_ms(unsigned int);sbit RS = P2^5;sbit RW = P2^6;sbit en = P2^7;unsigned char R,C,ch;unsigned char Key[4][4]={'0','1','2','3','4', '5','6','7','8','9', 'A','B','C','D','E','F'};void main(){ P1=0xff; DATA=0x00;lcd_init(); delay_ms(100);lcd_cmd (0x80); while(1) { key_scan(); delay_ms (5); ch = Key[R][C]; delay_ms(5); lcd_display(ch);delay_ms(5); lcd_cmd(0x01); }}void key_scan (void){ P1=0x0F; while (P1==0x0F); if(P1== 0x0D) R = 0; else if (P1==0x0B); R = 1; else if (P1==0x0D); R = 2; else if (P1==0x07); R = 3; P1=0xF0; while (P1==0xF0); if(P1==0xE0); C = 0 else if (P1==0xD0); C = 1 else if (P1==0xB0); C = 2 else if (P1==0x70); C = 3 delay_ms (20);}void lcd_cmd(unsigned char cmnd){ DATA = cmnd RS=0;RW=0;en=1; delay_ms(10); en=0;}void lcd_display(unsigned char dat){ DATA = dat; RS=1;RW=0;en=1; delay_ms(10); en=0;}void lcd_init (void){ lcd_cmd (0x38); lcd_cmd (0x0e); lcd_cmd (0x06); lcd_cmd (0x01);}void delay_ms(unsigned int k){ unsigned int i,j; for(i=0;i<=k;i++) { for(j=0;j<1275;j++); }}
can anyone find the error in this program.Its giving an error in the highlighted line.The error is error C141: syntax error near '=', expected '__asm'
Your definition of DATA is wrong.
