I couldn't find the "ılk_proje" file in the "objects" folder. What can I do please help.
You can't download a project that hasn't built properly.
Either the compile or link failed, or your script points to a file/directory that is incorrect.
Thank you Westonsupermare Pier for your reply "Either the compile or link failed, or your script points to a file/directory that is incorrect."How do I solve either the compile or link failed?I'm new at keill.
Start with the build log, review that. Will usually flag a bunch of errors and warnings. Start with the first one as others may cascade from that.
sebo said:I'm new at keill
It's no different to how you'd do it any any other IDE.
If you're new, maybe start here: http://www2.keil.com/mdk5/learn
When you do a build, it will tell you whether it succeeded or failed.
If it failed, there will be a list of error (and, possibly, warning) messages. Those messages (aka "diagnostics") tell you what went wrong - so you need to fix those things.
https://www.keil.com/support/man/docs/uv4/uv4_ui_error_list.htm
Note that one problem early in the build will often cause a number - possibly a large number - of resulting errors later in the build; hence it's important to address the earliest diagnostic first.
