Hallo everyone.uhh latley i have been have issue when i auto generate a code with cubemx it doesnt load the startp s file for the board as you can see in the text underBuild started: Project: test*** Using Compiler 'V6.14', folder: 'C:\Keil_v5\ARM\ARMCLANG\Bin'Build target 'Target 1'ArmClang: error: no such file or directory: 'D:/Documents/TEST/RTE/Device/STM32F030R8Tx/STCubeGenerated/MDK-ARM/startup_stm32f030x8.s'ArmClang: error: no input filesassembling startup_stm32f030x8.s...".\Objects\test.axf" - 2 Error(s), 0 Warning(s).Target not created.Build Time Elapsed: 00:00:00
i have a work around it but it still strange why is this happening because a couple a weeks ago it didnt have this issue.
does anybody know how to fix this?
DEVICES:
KEIL 5.3VSTMCUBE: 5.6Vboard: STM32F030R8
Hi,Visibly "D:/Documents/TEST/RTE/Device/STM32F030R8Tx/STCubeGenerated/MDK-ARM/startup_stm32f030x8.s" does not exist ?Be sure of your path and write autorisation... I'm not sur but some directories may be created manually before it.Regards
Hi Mitchellpk93
In case you are still looking for assistance with this, I have moved your thread to the Keil forum.
Oli from the Community team
