I have an old MDK-ARM Plus License. Furthermore it say "mdk_std" and "Support: Jan 2019". Before installing the update, I would like to make sure if I can use the latest µVisio. I don't have to use the latest compiler. Just the new GUI would be nice.
You can input your PSN or LIC into the following link to check and download all the versions supported by your license:
www.keil.com/.../
Thank you, but since I have a flex license, it is not so easily possible I guess
In this case, you can compare your support expiration date of your flex license with the release notes of MDK versions: https://www.keil.com/update/rvmdk.asp
Your expired license will only support you to use MDK versions that were released before your license support expiration date.
