I am getting this error message in the component viewer
To m it seems that it says that the RTX5 Kernel itself is missing, which cannot be.
Or do I have the wrong version. The error message says 5.7.0 and I have 5.5.2
I recommend.:
- to assure that all components (MDK, Packs) are updated to the latest releases
- to also compare your project with a corresponding example project matching your target, offered by the Pack Installer
Over on this thread What does this message mean? osRtxInfo not found you found the answer: update project files identified with blue question mark or yellow alert icons. Marking this issue as solved could be helpful for others.
Adam Lins said:Marking this issue as solved could be helpful for others
Indeed - and here's how:
