I have development board with Chinese ARM926EJ-S MCU. It also has NAND flash for booting and SDRAM. I also have a sample project developed in ADS 1.2 and LPT JLINK which works only in Windows XP. I never used that JTAG.
I migrated that project into KEIL 5. Compiled binary file burned into NAND by external tools is working now with MCU. I want to use JTAG debugging with Segger Jlink.
In accordance of this https://www.keil.com/pack/doc/CMSIS/Pack/html/cp_SWComponents.html I created a software pack for KEIL. Now in Keil I can select my MCU.
When I start Debugging in Keil I see log message "No Algorithm found for: 32100000H - 3210FFFFH". As I see Keil tries to burn the binary file into flash memory. Mentioned addresses are internal execution memory of my MCU (it is RAM memory for code).
What I have to do for loading execution code into that memory space and start execution. At this time I don't need NAND flash programming.
