Related, in part, to:community.arm.com/.../usb-----vcom
In the virtual COM usb sample from keil, why are there functions declared in rl_usb.h:
(I cannot attach the code for some reason) that are not implemented in USBD_User_CDC_ACM_UART_0.c:
/*------------------------------------------------------------------------------ * MDK Middleware - Component ::USB:Device * Copyright (c) 2004-2019 ARM Germany GmbH. All rights reserved. *------------------------------------------------------------------------------ * Name: USBD_User_CDC_ACM_UART_0.c * Purpose: USB Device Communication Device Class (CDC) * Abstract Control Model (ACM) USB <-> UART Bridge User module * Rev.: V1.0.3 *----------------------------------------------------------------------------*/ /** * \addtogroup usbd_cdcFunctions * * USBD_User_CDC_ACM_UART_0.c implements the application specific * functionality of the CDC ACM class and is used to demonstrate a USB <-> UART * bridge. All data received on USB is transmitted on UART and all data * received on UART is transmitted on USB. * * Details of operation: * UART -> USB: * Initial reception on UART is started after the USB Host sets line coding * with SetLineCoding command. Having received a full UART buffer, any * new reception is restarted on the same buffer. Any data received on * the UART is sent over USB using the CDC0_ACM_UART_to_USB_Thread thread. * USB -> UART: * While the UART transmit is not busy, data transmission on the UART is * started in the USBD_CDC0_ACM_DataReceived callback as soon as data is * received on the USB. Further data received on USB is transmitted on * UART in the UART callback routine until there is no more data available. * In this case, the next UART transmit is restarted from the * USBD_CDC0_ACM_DataReceived callback as soon as new data is received * on the USB. * * The following constants in this module affect the module functionality: * * - UART_PORT: specifies UART Port * default value: 0 (=UART0) * - UART_BUFFER_SIZE: specifies UART data Buffer Size * default value: 512 * * Notes: * If the USB is slower than the UART, data can get lost. This may happen * when USB is pausing during data reception because of the USB Host being * too loaded with other tasks and not polling the Bulk IN Endpoint often * enough (up to 2 seconds of gap in polling Bulk IN Endpoint may occur). * This problem can be solved by using a large enough UART buffer to * compensate up to a few seconds of received UART data or by using UART * flow control. * If the device that receives the UART data (usually a PC) is too loaded * with other tasks it can also loose UART data. This problem can only be * solved by using UART flow control. * * This file has to be adapted in case of UART flow control usage. */ //! [code_USBD_User_CDC_ACM] #include <stdbool.h> #include "rl_usb.h" #if defined(RTE_CMSIS_RTOS2) #include "cmsis_os2.h" #if defined(RTE_CMSIS_RTOS2_RTX5) #include "rtx_os.h" #endif #endif #if defined(RTE_CMSIS_RTOS) #include "cmsis_os.h" #endif #include "Driver_USART.h" // UART Configuration ---------------------------------------------------------- #define UART_PORT 1 // UART Port number #define UART_BUFFER_SIZE 512 // UART Buffer Size //------------------------------------------------------------------------------ #define _UART_Driver_(n) Driver_USART##n #define UART_Driver_(n) _UART_Driver_(n) extern ARM_DRIVER_USART UART_Driver_(UART_PORT); #define ptrUART (&UART_Driver_(UART_PORT)) // External functions #ifdef USB_CMSIS_RTOS extern void CDC0_ACM_UART_to_USB_Thread (void const *arg) __attribute((noreturn)); #endif // Local Variables static uint8_t uart_rx_buf[UART_BUFFER_SIZE]; static uint8_t uart_tx_buf[UART_BUFFER_SIZE]; static volatile int32_t uart_rx_cnt = 0; static volatile int32_t usb_tx_cnt = 0; static void *cdc_acm_bridge_tid = 0U; static CDC_LINE_CODING cdc_acm_line_coding = { 0U, 0U, 0U, 0U }; // Called when UART has transmitted or received requested number of bytes. // \param[in] event UART event // - ARM_USART_EVENT_SEND_COMPLETE: all requested data was sent // - ARM_USART_EVENT_RECEIVE_COMPLETE: all requested data was received static void UART_Callback (uint32_t event) { int32_t cnt; if (event & ARM_USART_EVENT_SEND_COMPLETE) { // USB -> UART cnt = USBD_CDC_ACM_ReadData(0U, uart_tx_buf, UART_BUFFER_SIZE); if (cnt > 0) { ptrUART->Send(uart_tx_buf, (uint32_t)(cnt)); } } if (event & ARM_USART_EVENT_RECEIVE_COMPLETE) { // UART data received, restart new reception uart_rx_cnt += UART_BUFFER_SIZE; ptrUART->Receive(uart_rx_buf, UART_BUFFER_SIZE); } } // Thread: Sends data received on UART to USB // \param[in] arg not used. #ifdef USB_CMSIS_RTOS2 __NO_RETURN static void CDC0_ACM_UART_to_USB_Thread (void *arg) { #else __NO_RETURN void CDC0_ACM_UART_to_USB_Thread (void const *arg) { #endif int32_t cnt, cnt_to_wrap; (void)(arg); while (1) { // UART - > USB if (ptrUART->GetStatus().rx_busy != 0U) { cnt = uart_rx_cnt; cnt += ptrUART->GetRxCount(); cnt -= usb_tx_cnt; if (cnt >= UART_BUFFER_SIZE) { // Dump data received on UART if USB is not consuming fast enough usb_tx_cnt += cnt; cnt = 0U; } if (cnt > 0) { cnt_to_wrap = (int32_t)(UART_BUFFER_SIZE - ((uint32_t)usb_tx_cnt & (UART_BUFFER_SIZE - 1))); if (cnt > cnt_to_wrap) { cnt = cnt_to_wrap; } cnt = USBD_CDC_ACM_WriteData(0U, (uart_rx_buf + ((uint32_t)usb_tx_cnt & (UART_BUFFER_SIZE - 1))), cnt); if (cnt > 0) { usb_tx_cnt += cnt; } } } osDelay(10U); } } #ifdef USB_CMSIS_RTOS2 #ifdef USB_CMSIS_RTOS2_RTX5 static osRtxThread_t cdc0_acm_uart_to_usb_thread_cb_mem __SECTION(.bss.os.thread.cb); static uint64_t cdc0_acm_uart_to_usb_thread_stack_mem[512U / 8U] __SECTION(.bss.os.thread.stack); #endif static const osThreadAttr_t cdc0_acm_uart_to_usb_thread_attr = { "CDC0_ACM_UART_to_USB_Thread", 0U, #ifdef USB_CMSIS_RTOS2_RTX5 &cdc0_acm_uart_to_usb_thread_cb_mem, sizeof(osRtxThread_t), &cdc0_acm_uart_to_usb_thread_stack_mem[0], #else NULL, 0U, NULL, #endif 512U, osPriorityNormal, 0U, 0U }; #else extern const osThreadDef_t os_thread_def_CDC0_ACM_UART_to_USB_Thread; osThreadDef (CDC0_ACM_UART_to_USB_Thread, osPriorityNormal, 1U, 0U); #endif // CDC ACM Callbacks ----------------------------------------------------------- // Called when new data was received from the USB Host. // \param[in] len number of bytes available to read. void USBD_CDC0_ACM_DataReceived (uint32_t len) { int32_t cnt; (void)(len); if (ptrUART->GetStatus().tx_busy == 0U) { // Start USB -> UART cnt = USBD_CDC_ACM_ReadData(0U, uart_tx_buf, UART_BUFFER_SIZE); if (cnt > 0) { ptrUART->Send(uart_tx_buf, (uint32_t)(cnt)); } } } // Called during USBD_Initialize to initialize the USB CDC class instance (ACM). void USBD_CDC0_ACM_Initialize (void) { ptrUART->Initialize (UART_Callback); ptrUART->PowerControl (ARM_POWER_FULL); #ifdef USB_CMSIS_RTOS2 cdc_acm_bridge_tid = osThreadNew (CDC0_ACM_UART_to_USB_Thread, NULL, &cdc0_acm_uart_to_usb_thread_attr); #else cdc_acm_bridge_tid = osThreadCreate (osThread (CDC0_ACM_UART_to_USB_Thread), NULL); #endif } // Called during USBD_Uninitialize to de-initialize the USB CDC class instance (ACM). void USBD_CDC0_ACM_Uninitialize (void) { if (osThreadTerminate (cdc_acm_bridge_tid) == osOK) { cdc_acm_bridge_tid = NULL; } ptrUART->Control (ARM_USART_ABORT_RECEIVE, 0U); ptrUART->PowerControl (ARM_POWER_OFF); ptrUART->Uninitialize (); } // Called upon USB Bus Reset Event. void USBD_CDC0_ACM_Reset (void) { ptrUART->Control (ARM_USART_ABORT_SEND, 0U); ptrUART->Control (ARM_USART_ABORT_RECEIVE, 0U); } // Called upon USB Host request to change communication settings. // \param[in] line_coding pointer to CDC_LINE_CODING structure. // \return true set line coding request processed. // \return false set line coding request not supported or not processed. bool USBD_CDC0_ACM_SetLineCoding (const CDC_LINE_CODING *line_coding) { uint32_t data_bits = 0U, parity = 0U, stop_bits = 0U; int32_t status; ptrUART->Control (ARM_USART_ABORT_SEND, 0U); ptrUART->Control (ARM_USART_ABORT_RECEIVE, 0U); ptrUART->Control (ARM_USART_CONTROL_TX, 0U); ptrUART->Control (ARM_USART_CONTROL_RX, 0U); switch (line_coding->bCharFormat) { case 0: // 1 Stop bit stop_bits = ARM_USART_STOP_BITS_1; break; case 1: // 1.5 Stop bits stop_bits = ARM_USART_STOP_BITS_1_5; break; case 2: // 2 Stop bits stop_bits = ARM_USART_STOP_BITS_2; } switch (line_coding->bParityType) { case 0: // None parity = ARM_USART_PARITY_NONE; break; case 1: // Odd parity = ARM_USART_PARITY_ODD; break; case 2: // Even parity = ARM_USART_PARITY_EVEN; break; default: return false; } switch (line_coding->bDataBits) { case 5: data_bits = ARM_USART_DATA_BITS_5; break; case 6: data_bits = ARM_USART_DATA_BITS_6; break; case 7: data_bits = ARM_USART_DATA_BITS_7; break; case 8: data_bits = ARM_USART_DATA_BITS_8; break; default: return false; } status = ptrUART->Control(ARM_USART_MODE_ASYNCHRONOUS | data_bits | parity | stop_bits | ARM_USART_FLOW_CONTROL_NONE , line_coding->dwDTERate ); if (status != ARM_DRIVER_OK) { return false; } // Store requested settings to local variable cdc_acm_line_coding = *line_coding; uart_rx_cnt = 0; usb_tx_cnt = 0; ptrUART->Control (ARM_USART_CONTROL_TX, 1U); ptrUART->Control (ARM_USART_CONTROL_RX, 1U); ptrUART->Receive (uart_rx_buf, UART_BUFFER_SIZE); return true; } // Called upon USB Host request to retrieve communication settings. // \param[out] line_coding pointer to CDC_LINE_CODING structure. // \return true get line coding request processed. // \return false get line coding request not supported or not processed. bool USBD_CDC0_ACM_GetLineCoding (CDC_LINE_CODING *line_coding) { // Load settings from ones stored on USBD_CDC0_ACM_SetLineCoding callback *line_coding = cdc_acm_line_coding; return true; } // Called upon USB Host request to set control line states. // \param [in] state control line settings bitmap. // - bit 0: DTR state // - bit 1: RTS state // \return true set control line state request processed. // \return false set control line state request not supported or not processed. bool USBD_CDC0_ACM_SetControlLineState (uint16_t state) { // Add code for set control line state (void)(state); return true; } //! [code_USBD_User_CDC_ACM]
The following lines define UART port numbers, buffer sizes and serial communication config:
CDC_LINE_CODING appears to be what's needed in order to tweak serial config. In USBD_User_CDC_ACM_UART_0.c
there are two functions (USBD_CDC0_ACM_SetLineCoding() and USBD_CDC0_ACM_GetLineCoding()) that should be useful to that end; the problem is that
they're not callable from the outside (not declared in rl_usb.h). Questions:
