OOP rules for global objects
What I do in my current project:
1- I've developed a library by using C++ (compiler: arm-none-eabi-g++ -std=c++17) and generated a static library (arm-none-eabi-ar) with some c-api wrapper functions. In the static library there are some global instances of some classes, and exposed c functions provide access to their functionality
2- I've developed the app (compiler: arm-none-eabi-gcc) to be run on an ARM chip and linked with the static library. In the main function, a call is made to an init function which is in the static library
My observation is that, if I am not wrong, OOP inheritance rules don't work on those global objects. If I take a global object into a member function as a local variable, then I can access it via a pointer of its base class. A sample code is below:
Some test classes:
class CtBase
public:
    virtual void foo(void) = 0;
    int i = 0;
class CtDer : public CtBase
public:
    void foo(void) override;
void CtDer::foo(void)
    ++this->i;
Use them in a class member function implementation, where its instance (PlatformDevice) is a global object in the static library:
Version 1 - Doesn't work
CtDer der;
namespace mevoo::loni6
    void PlatformDevice::init(UdpComm *udp, BufferBase *b)
        CtBase *ctptr = &der;
        ctptr->foo(); // doesn't work
// some more code
Version 2 - works:
        CtDer der; // now a local var
        ctptr->foo(); // works
// some more code
Any comment would be highly appreciated.
Best regards,
Ozan
