Hi Everyone
I am merging libucv(library USB Video class) files into my Keil code. But I got the error that pthread.h is not included. I was searching online and it says Keil does not support pthread.
Is there any way I can manually add pthread library or file to my code?
I will really appreciate any suggestions.
You can manually add the header file to your project:http://www.keil.com/support/docs/1740.htm
Please note that pthread is usually something available in Linux https://en.wikipedia.org/wiki/POSIX_Threads .
MDK is used for Cortex-M development, which basically uses RTOS, instead of linux. That's why you cannot find pthread.h in arm compiler toolchain installed by MDK
Thanks Chen Tang for sharing the information
Thanks Sankalp Agarwal for confirming this.
