Dear all,
I an in need of coding...... Using arm board TMS570LC4357......Coding required for sending output timing singnal after crossing 58 teeth on a 60 teeth trigger wheel.....Two teeth were removed (59th and 60th).....
Need to count the teeth upto 58......after corssing removed teeth the count should restart..... and timing signal should be sent after crossing 58th teeth before reset....
Kindly help me in this coding.....
Thanking you,
SHIVAKUMAR
This has nothing to do with Keil or ARM - you need to go to TI for support with using their chips
See: https://community.arm.com/developer/tools-software/tools/f/keil-forum/43684/lpc2148-timer0-not-working-as-expected/158950#158950
Go to the TI page for the TMS570LC4357:
https://www.ti.com/product/TMS570LC4357
There you will find all the necessary documentation, support, examples, etc:
