How to debug through malloc function?
Hi All,
I am using EFM32GG11 cpu and have problem with malloc function. It crashes on the first call.
I have specified stack and heap areas in the scatter file.
I would like to debug through malloc function. I am using the standart C library linked to my keil MDK 5 project,
How could i build c runtime and link it to my project?
Thanks,
  • Define "crashes"
    Where does the processor end up?
    If you have a Hard Fault you're touching some memory oddly. Check that the memory described to the linker matches the capabilities of the part.
    Check how memory is arranged in the .MAP file.
    Make sure your SystemInit() code enables clocks, external memories, etc.
    Use FromELF to disassemble the .AXF file so you can play along with the debugger. You can step into code where you lack source, it is not that hard.
    Pretty sure Keil's code is solid, so issue is likely with structures, or initialization.
    Also shouldn't be hard to figure the linked-list implementation, and walk the heap structures.
    Check structure alignment, CM4 will fault on unaligned access with LDRD,STRD
  • Hello,
    Thanks for reply. I have checked that HardFauld occur due to read at 0xFFFFFFFF address. Somehow this address is calculated inside malloc function. I currently far from being able to walk in disassembly and check what happens with linked list.
    I have some troubles with scatter file. I found an example scatter file without heap definition.
    I have defined ARM_LIB_HEAP variable.
    ARM_LIB_HEAP 0x2007F000 EMPTY  HeapSize {
    There is a
    RW_IRAM1 0x20000158 0x0007EEA8 { ; RW data
    .ANY (+RW +ZI)
    region for RAM.
    I have added another region for heap
    RW_IRAM2 0x2007F000 0xC00 { ; RW data
    .ANY (+RW +ZI)
    Still Hard fault.
    I would like to find out how C runtime library initialize it's internal variables for heap base?
    Maybe some init function must be called before C runtime?
    My systeminit function is called and clocks are initialized, without malloc cpu is working fine.
  • The Heap/Stack are more usually defined in startup.s
    ; Amount of memory (in bytes) allocated for Stack
    ; Tailor this value to your application needs
    ; <h> Stack Configuration
    ;   <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
    ; </h>
    Stack_Size      EQU     0x0800
                    AREA    STACK, NOINIT, READWRITE, ALIGN=3
    Stack_Mem       SPACE   Stack_Size
    __initial_sp
    ; <h> Heap Configuration
    ;   <o>  Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
    ; </h>
    Heap_Size       EQU     0x2000
                    AREA    HEAP, NOINIT, READWRITE, ALIGN=3
    __heap_base
    Heap_Mem        SPACE   Heap_Size
    __heap_limit
  • When using MicroLib, exporting
                     EXPORT  __initial_sp
                     EXPORT  __heap_base
                     EXPORT  __heap_limit
  • What the plumbing looks like
    From .MAP
        HEAP                                     0x20002c50   Section     8192  startup_stm32l432xx.o(HEAP)
        __microlib_freelist                      0x20000004   Data           4  mvars.o(.data)
        __microlib_freelist_initialised          0x20000008   Data           4  mvars.o(.data)
        __heap_base                              0x20002c50   Data           0  startup_stm32l432xx.o(HEAP)
        __heap_limit                             0x20004c50   Data           0  startup_stm32l432xx.o(HEAP)
        __initial_sp                             0x20005450   Data           0  startup_stm32l432xx.o(STACK)
    FromELF Listing
        i.malloc
        malloc
            0x08006f2c:    b5f0        ..      PUSH     {r4-r7,lr}
            0x08006f2e:    300b        .0      ADDS     r0,r0,#0xb
            0x08006f30:    4d15        .M      LDR      r5,[pc,#84] ; [0x8006f88] = 0x20000008
            0x08006f32:    f0200107     ...    BIC      r1,r0,#7
            0x08006f36:    2400        .$      MOVS     r4,#0
            0x08006f38:    4a14        .J      LDR      r2,[pc,#80] ; [0x8006f8c] = 0x20000004
            0x08006f3a:    e00f        ..      B        0x8006f5c ; malloc + 48
            0x08006f3c:    6803        .h      LDR      r3,[r0,#0]
            0x08006f3e:    428b        .B      CMP      r3,r1
            0x08006f40:    d30b        ..      BCC      0x8006f5a ; malloc + 46
            0x08006f42:    428b        .B      CMP      r3,r1
            0x08006f44:    d905        ..      BLS      0x8006f52 ; malloc + 38
            0x08006f46:    1a5e        ^.      SUBS     r6,r3,r1
            0x08006f48:    1843        C.      ADDS     r3,r0,r1
            0x08006f4a:    6847        Gh      LDR      r7,[r0,#4]
            0x08006f4c:    e9c36700    ...g    STRD     r6,r7,[r3,#0]
            0x08006f50:    e000        ..      B        0x8006f54 ; malloc + 40
            0x08006f52:    6843        Ch      LDR      r3,[r0,#4]
            0x08006f54:    6013        .`      STR      r3,[r2,#0]
            0x08006f56:    c002        ..      STM      r0!,{r1}
            0x08006f58:    e004        ..      B        0x8006f64 ; malloc + 56
            0x08006f5a:    1d02        ..      ADDS     r2,r0,#4
            0x08006f5c:    6810        .h      LDR      r0,[r2,#0]
            0x08006f5e:    2800        .(      CMP      r0,#0
            0x08006f60:    d1ec        ..      BNE      0x8006f3c ; malloc + 16
            0x08006f62:    4620         F      MOV      r0,r4
            0x08006f64:    2800        .(      CMP      r0,#0
            0x08006f66:    d102        ..      BNE      0x8006f6e ; malloc + 66
            0x08006f68:    6828        (h      LDR      r0,[r5,#0]
            0x08006f6a:    b108        ..      CBZ      r0,0x8006f70 ; malloc + 68
            0x08006f6c:    2000        .       MOVS     r0,#0
            0x08006f6e:    bdf0        ..      POP      {r4-r7,pc}
            0x08006f70:    4a06        .J      LDR      r2,[pc,#24] ; [0x8006f8c] = 0x20000004
            0x08006f72:    4807        .H      LDR      r0,[pc,#28] ; [0x8006f90] = 0x20002c54
            0x08006f74:    6010        .`      STR      r0,[r2,#0]
            0x08006f76:    4a07        .J      LDR      r2,[pc,#28] ; [0x8006f94] = 0x20004c50
            0x08006f78:    1a12        ..      SUBS     r2,r2,r0
            0x08006f7a:    f0220207    "...    BIC      r2,r2,#7
            0x08006f7e:    e9c02400    ...$    STRD     r2,r4,[r0,#0]
            0x08006f82:    2001        .       MOVS     r0,#1
            0x08006f84:    6028        (`      STR      r0,[r5,#0]
            0x08006f86:    e7d7        ..      B        0x8006f38 ; malloc + 12
        $d
            0x08006f88:    20000008    ...     DCD    536870920 __microlib_freelist_initialised
            0x08006f8c:    20000004    ...     DCD    536870916 __microlib_freelist
            0x08006f90:    20002c54    T,.     DCD    536882260 __heapbase + 4
            0x08006f94:    20004c50    PL.     DCD    536890448 __heaplimit
        $t
  • Annotated listing
    08006F2C        SUB16   malloc:                         ; Xref 8001E6C 8002B48
    08006F2C B5F0                   push    {r4, r5, r6, r7, lr}
    08006F2E 300B                   adds    r0, #11
    08006F30 4D15                   ldr     r5, [pc, #84]   ; ($8006F88=$20000008) __microlib_freelist_initialised
    08006F32 F020 0107              bic.w   r1, r0, #7      ; $7
    08006F36 2400                   movs    r4, #0          ; NULL
    08006F38        LOC     loc_8006F38:                    ; Xref 8006F86
    08006F38 4A14                   ldr     r2, [pc, #80]   ; ($8006F8C=$20000004) __microlib_freelist
    08006F3A E00F                   b.n     loc_8006F5C
    08006F3C        LOC     loc_8006F3C:                    ; Xref 8006F60
    08006F3C 6803                   ldr     r3, [r0, #0]
    08006F3E 428B                   cmp     r3, r1
    08006F40        LOC     loc_8006F40:                    ; Xref 8006FC6
    08006F40 D30B                   bcc.n   loc_8006F5A
    08006F42 428B                   cmp     r3, r1
    08006F44 D905                   bls.n   loc_8006F52
    08006F46 1A5E                   subs    r6, r3, r1
    08006F48 1843                   adds    r3, r0, r1
    08006F4A 6847                   ldr     r7, [r0, #4]
    08006F4C E9C3 6700              strd    r6, r7, [r3]
    08006F50 E000                   b.n     loc_8006F54
    08006F52        LOC     loc_8006F52:                    ; Xref 8006F44
    08006F52 6843                   ldr     r3, [r0, #4]
    08006F54        LOC     loc_8006F54:                    ; Xref 8006F50
    08006F54 6013                   str     r3, [r2, #0]
    08006F56 C002                   stmia   r0!, {r1}
    08006F58 E004                   b.n     loc_8006F64
    08006F5A        LOC     loc_8006F5A:                    ; Xref 8006F40
    08006F5A 1D02                   adds    r2, r0, #4
    08006F5C        LOC     loc_8006F5C:                    ; Xref 8006F3A
    08006F5C 6810                   ldr     r0, [r2, #0]
    08006F5E 2800                   cmp     r0, #0
    08006F60 D1EC                   bne.n   loc_8006F3C
    08006F62 4620                   mov     r0, r4
    08006F64        LOC     loc_8006F64:                    ; Xref 8006F58
    08006F64 2800                   cmp     r0, #0
    08006F66 D102                   bne.n   loc_8006F6E     ; allocation success, leave
    08006F68 6828                   ldr     r0, [r5, #0]    ; [__microlib_freelist_initialised]
    08006F6A B108                   cbz     r0, loc_8006F70 ; init == 0?
    08006F6C 2000                   movs    r0, #0
    08006F6E        LOC     loc_8006F6E:                    ; Xref 8006F66
    08006F6E BDF0                   pop     {r4, r5, r6, r7, pc}
    08006F70        LOC     loc_8006F70:                    ; Xref 8006F6A
    08006F70 4A06                   ldr     r2, [pc, #24]   ; ($8006F8C=$20000004) __microlib_freelist
    08006F72 4807                   ldr     r0, [pc, #28]   ; ($8006F90=$20002C54) __heap_base + 4
    08006F74 6010                   str     r0, [r2, #0]
    08006F76 4A07                   ldr     r2, [pc, #28]   ; ($8006F94=$20004C50) __heap_limit
    08006F78 1A12                   subs    r2, r2, r0
    08006F7A F022 0207              bic.w   r2, r2, #7      ; $7
    08006F7E        LOC     loc_8006F7E:                    ; Xref 8006FC0
    08006F7E E9C0 2400              strd    r2, r4, [r0]    ; linked list (size this, prev)
    08006F82 2001                   movs    r0, #1
    08006F84 6028                   str     r0, [r5, #0]    ; init = 1
    08006F86        LOC     loc_8006F86:                    ; Xref 8006FC8
    08006F86 E7D7                   b.n     loc_8006F38
    08006F88        LOC     loc_8006F88:                    ; Xref 8006FCA
    08006F88 20000008               dd      $20000008
    08006F8C 20000004               dd      $20000004
    08006F90 20002C54               dd      $20002C54
    08006F94 20004C50               dd      $20004C50
  • Unfortunately i am not using MicroLib. I am using default C library. (no check in Keil Project options for Use MicroLib).
    Currently i can't understand one issue. I have specified the scatter file to the linker. I have
    ARM_LIB_HEAP 0x2007F000 EMPTY  HeapSize { }
    line.
    Nut in .map file i see
    HEAP 0x20019cc8 Section 3072 startup_efm32gg11b.o(HEAP)
    Heap_Mem 0x20019cc8 Data 3072 startup_efm32gg11b.o(HEAP)
    Why address is 0x20019cc8  and not 0x2007F000 ? I can't understand.
