Code that causes freeze when in main function scope
Hello everyone,
I just started to study ARM this week and i was trying to retarget printf to make it work with UART. After many tries, it just started to work magically as i put the stdin and stdout lines(#16 &17) out of the main function scope. What's the reason behind it? Is it something Keil related? Is it due to the some rules of C, memory issues or stdio.h? By the way, even if i put those lines in the main function scope, it's working in debugger mode. But it stops at command BKPK 0xAB line but i'm not at that level to understand if that means something.
Thank you for your time!
0
