due to our software process we need to know which library versions are Included in ARMClang 6.10
Due to Arm® Compiler armclang Reference Guide (https://developer.arm.com/docs/100067/0610, p. 1-21), I see (attached picture) that ARM-C-library, ARM-C++-library and libc++ are used.
Where can I find information which version of the library is used? Is it possible to trace it with defines, like __LIBCXX_VERSION? I didn't found any information due to which versions of the library are included in ARMclang 6.10
If I check <InstallPath>\ARM\ARMCLANG\sw\info\thirdpartylicenses, I find the licenses but not the versiosn.
Thanks a lot.
in case that:
1. the Release Notes of ARMClang 6.10 are not helpful...:
https://developer.arm.com/tools-and-software/embedded/arm-compiler/downloads/version-6/6-10-1
2. ...and if the file properties (to view information about a file or folder, right-click it and select Properties) are not answering your question...:
3. ...then :
- open A Support Ticket according to www2.keil.com/.../silver
- and provide a valid serial number (PSN/LIC) confirming your entitlement to our Support
