I work with the STM32F407 board I want to make an MP3 player there are good examples on the internet, The problem is that I cannot compile helix library to decode mp3 files in keil due to the fact that there are some functions in assembler, I think the options are to encode this function in C or compile assembler in keil.Someone can code this function in C !!
MADD64(sum, x, y) (Windows only) sum [64-bit] += x [32-bit] * y [32-bit]
typedef union _U64 {Word64 w64;struct {/ * ARM ADS = little endian * /unsigned int lo32;signed int hi32;} r;} U64;
static __inline Word64 MADD64 (Word64 sum64, int x, int y){U64 u;u.w64 = sum64;
__asm__ volatile ("smlal% 0,% 1,% 2,% 3": "+ & r" (urlo32), "+ & r" (urhi32): "r" (x), "r" (y): "DC");
return u.w64;}
JossFragas said:there are good examples on the internet
So why don't you just pick one that you can build ?
And one which has support.
What toolchain is this example intended for?
Note that inline assembler is not portable - so you need to use the correct toolchain for it.
