Debugging STM32L103RE ... no C debugging with ULINK but there with simulator
I have been using MDK-ARM for about 13 years - normally works well.
I have a project now that uses a STM32F103RE uC. Project packs based, RTOS2.  The CMSIS / rtos project compiles in a library for ST drivers and a library for the application.   Both libs are of my creation.
Using the exact same compile, I can debug nicely using simulator for the CPU variant.   It steps through C level source, shows C in the disassembly window, and such as expected.   When switching to the uLINK debugger (choose hardware rather than sim in options->debug  tab,  NO rebuild / recompile / etc) it will only step through assembly.  NO C listed in assembly.   Program runs identical on real hardware as it dose simulator.
Same PCB with same ulink and other projects source level debug fine.
Looking for suggestions.  IF it was a different build between simulator and hardware I could see info not being in debugger files but with same build I am at a loss.
Thanks,
CHad
  • I expect that with 13 years of using MDK you possess a valid license key. In this case you are entitled to open a Support Ticket according to: http://www2.keil.com/support/silver
       - Attach to this ticket your project
       - confirm the MDK version in use
       - and detail the problem you face.
    We will then trigger a closer investigation, thanks Chad
  • Sure do.  Case submitted. Will see where that goes.
    I now find the "debug" build works fine for both hardware and simulator.  It is the release  build ( optimization 3 vs 0 or 1  and a couple sim script support items are optionally compiled out release).  MAP file looks quite similar.  file sizes for map and axf nearly the same as well.
    profiles have Options->Output->Debug / hex / browse checked
    Options->Output->Listing:  No assembler / C checked.
    Linker:  mem map / symbols / size / totals checked.
    Chad
  • To close this off,
    For some reason the multi project ( 2 x .lib linked into main project) required symbols to be reloaded with the following in the short hardware debug.ini file:
    LOAD %L INCREMENTAL NOCODE
