I`ve added the .c with .h files to project. After removed them both from folders. But now got compiler error. Seems compiler still searching for it. How to fix it?
Using Keil uVision
*** Using Compiler 'V5.06 update 6 (build 750)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin' Build target 'ROOM_LIGHT' compiling hdc1080.c... "no source": Error: #5: cannot open source input file "..\Src\hdc1080.c": No such file or directory ..\Src\hdc1080.c: 0 warnings, 1 error "ROOM_LIGHT\ROOM_LIGHT.axf" - 1 Error(s), 0 Warning(s). Target not created. Build Time Elapsed: 00:00:00
IlgarSky said:After removed them both from folders
What, exactly, do you mean by that ?
If you've left them listed in the project, but deleted the files from your hard drive - then this is entirely expected behaviour!
OR
you're not #including the .c file in another .c file ... ?
I`ve add file (.c from Src folder) to project as usual in Keil. But removed it from project in Keil. After that deleted from project Src and Inc folders.
Now compiler trying to compile removed file. How to fix it, I`ve no idea.
still not entirely clear what you've done.
have you closed & restarted uVision - to ensure that the project has saved properly?
have you done a Clean before rebuilding?
have you tried manually deleting the output folder(s) before rebuilding?
1. I`ve restarted the IDE, but error stays
2. I pressed "Batch Clean" in IDE, compiled but error stays.
3. I`ve manually deleted all files in Output folder, compiled again, but error stays.
After re-compile in Output folder created hdc1080.d file again.
IlgarSky said:I pressed "Batch Clean" in IDE, compiled but error stays.
really?
You need 'Clean Targets', and then 'Rebuild all target files':
Ok. I did it now exactly. Cleaned all files in Output folders. But no changes.
You mean you clicked on the 'Clean Targets' option on the 'Project' menu - as shown?
And then you clicked on the 'Rebuild all target files' option?
Remember that we can't see your screen, and we can't see what you're doing - so it's up to you to describe clearly and completely and precisely what you have done.
I understand. I did exactly as you displayed in picture. The is no such file in Src and Inc folders. Cleaned, Rebuilded but error stays.
Now I cheat the compiler: Created blank hdc1080.c and hdc1080.h files and put them to the project folders. Compiled. Error gone :)It is strange but worked.
Note that the project files are just plain text - so you can look at them in a text editor, and search for references to your mystery files...
And, again, you're not #including the .c file in another .c file, are you ... ?
I looked that .c file in Notepad++. Found nothing unusual. It was about regular I2C data transfer procedure for HDC1080 temperature sensor. Here it was:
/* ****************************************************************************** * File Name : hdc1080.c * Description : hdc1080 driver ****************************************************************************** * * COPYRIGHT(c) 2016 s54mtb * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * ****************************************************************************** The hdc1080 communicates with the host controller over a digital I2C interface. The 7-bit base slave address is 0x40 or 0x41 */ #include "stm32f0xx_hal.h" #include "hdc1080.h" #include <string.h> #define HDC1080_ADDR 0x40 /* * hdc1080_read_reg() - Read User register * @hi2c: handle to I2C interface * @delay: Delay before read * @reg: Register address * @val: 16-bit register value from the hdc1080 * Returns HAL status or HAL_ERROR for invalid parameters. */ HAL_StatusTypeDef hdc1080_read_reg(I2C_HandleTypeDef *hi2c, uint16_t delay, uint8_t reg, uint16_t *val) { uint8_t buf[2]; HAL_StatusTypeDef error; // Check argument if ((reg != HDC1080_TEMPERATURE) & (reg != HDC1080_HUMIDITY) & (reg != HDC1080_CONFIG) & (reg != HDC1080_SERIAL_ID1) & (reg != HDC1080_SERIAL_ID2) & (reg != HDC1080_SERIAL_ID3) & (reg != HDC1080_ID_MANU) & (reg != HDC1080_ID_DEV) ) return HAL_ERROR; buf[0] = reg; /* Read register */ /* Send the read followed by address */ error = HAL_I2C_Master_Transmit(hi2c,HDC1080_ADDR<<1,buf,1,100); if (error != HAL_OK) return error; HAL_Delay(delay); /* Receive a 2-byte result */ error = HAL_I2C_Master_Receive(hi2c, HDC1080_ADDR<<1 | 0x01, buf, 2, 1000); if (error != HAL_OK) return error; /* Result */ *val = buf[0]*256+buf[1]; return HAL_OK; /* Success */ } /* * hdc1080_write_reg() - Write register * @hi2c: handle to I2C interface * @reg: Register address * @val: 8-bit register value from the Si7013 * Returns HAL status or HAL_ERROR for invalid arguments. */ HAL_StatusTypeDef hdc1080_write_reg(I2C_HandleTypeDef *hi2c, uint8_t reg, uint16_t val) { uint8_t buf[3]; HAL_StatusTypeDef error; // Check argument if ((reg != HDC1080_TEMPERATURE) & // dummy write to adr 0 ... trigger measurement (reg != HDC1080_CONFIG) ) // config is "writable" return HAL_ERROR; buf[0] = reg; buf[1] = (uint8_t)((val >> 8) & 0xff); // msb buf[2] = (uint8_t)(val & 0xff); // lsb /* Write the register */ /* Send the command and data */ error = HAL_I2C_Master_Transmit(hi2c,HDC1080_ADDR<<1,buf,3,100); if (error != HAL_OK) return error; else return HAL_OK; /* Success */ } /* * hdc1080_measure() - measure humididty and temperature: 1. Configure the acquisition parameters in config register (address 0x02): (a) Set the acquisition mode to measure both temperature and humidity by setting Bit[12] to 1. (b) Set the desired temperature measurement resolution: – Set Bit[10] to 0 for 14 bit resolution. – Set Bit[10] to 1 for 11 bit resolution. (c) Set the desired humidity measurement resolution: – Set Bit[9:8] to 00 for 14 bit resolution. – Set Bit[9:8] to 01 for 11 bit resolution. – Set Bit[9:8] to 10 for 8 bit resolution. 2. Trigger the measurements by writing I2C read reg. address with adr = HDC1080_TEMPERATURE. 3. Wait for the measurements to complete, based on the conversion time 4. Read the output data: Read the temperature data from register address 0x00, followed by the humidity data from register address 0x01 in a single transaction. A read operation will return a NACK if the contents of the registers have not been updated. * @hi2c: handle to I2C interface * @temp_res : temperature measurement resolution: * - HDC1080_T_RES_14 or * - HDC1080_T_RES_11 * @humidres : humidity readout resolution * - HDC1080_RH_RES_14 or * - HDC1080_RH_RES_11 or * - HDC1080_RH_RES_8 * @heater : heater enable (0 = disabled or 1 = enabled) * @bat_stat : supply voltage * - 0 when Ucc > 2,8V * - 1 when Ucc < 2,8V * @temperature : floating point temperature result, unit is °C * @humidity : floating point humidity result, unit is RH% * Returns HAL status. */ HAL_StatusTypeDef hdc1080_measure(I2C_HandleTypeDef *hi2c, uint8_t temp_res, uint8_t humidres, uint8_t heater, uint8_t *bat_stat, double *temperature, double *humidity) { HAL_StatusTypeDef error; uint16_t r; double tmp; error = hdc1080_read_reg(hi2c, 10, HDC1080_CONFIG, &r); if (error != HAL_OK) return error; r |= temp_res<<10; r |= humidres<<8; r |= 1<<12; // mode = 1; r |= heater<<13; *bat_stat = (r>>11) & 0x0001; // write config error = hdc1080_write_reg(hi2c, HDC1080_CONFIG, r); if (error != HAL_OK) return error; error = hdc1080_read_reg(hi2c, 150, HDC1080_TEMPERATURE, &r); if (error != HAL_OK) return error; tmp = (double)r; tmp = (tmp / 65536.0f) * 165.0f - 40.0f; *temperature = tmp; // °C error = hdc1080_read_reg(hi2c, 150, HDC1080_HUMIDITY, &r); tmp = (int32_t)r; if (error != HAL_OK) return error; tmp = (float)r; tmp = (tmp / 65536.0f) * 100.0f; if (tmp>100.0) tmp = 100.0f; if (tmp<0) tmp = 0.0f; *humidity = tmp; return HAL_OK; } /* * hdc1080_get_device_id() - Get the device ID from the device * @i2c: handle to I2C interface * @serial: 40 bit serial number * @manuf: 16 bit manufacturer ID * @device: 16 bit device ID * * Returns 0 on success. */ HAL_StatusTypeDef hdc1080_get_device_id(I2C_HandleTypeDef *hi2c, uint64_t *serial, uint16_t *manuf, uint16_t *device) { uint16_t ser[4]; HAL_StatusTypeDef error; error = hdc1080_read_reg(hi2c, 10, HDC1080_SERIAL_ID1, &ser[0]); if (error != HAL_OK) return error; error = hdc1080_read_reg(hi2c, 10, HDC1080_SERIAL_ID2, &ser[1]); if (error != HAL_OK) return error; error = hdc1080_read_reg(hi2c, 10, HDC1080_SERIAL_ID3, &ser[2]); if (error != HAL_OK) return error; ser[3] = 0; memcpy(serial, ser, 8); error = hdc1080_read_reg(hi2c, 10, HDC1080_ID_MANU, manuf); if (error != HAL_OK) return error; error = hdc1080_read_reg(hi2c, 10, HDC1080_ID_DEV, device); if (error != HAL_OK) return error; return HAL_OK; /* Success */ }
and .h file:
#ifndef __hdc1080_h__ #define __hdc1080_h__ #include "stm32f0xx_hal.h" /* Register addresses */ #define HDC1080_TEMPERATURE 0x00 #define HDC1080_HUMIDITY 0x01 #define HDC1080_CONFIG 0x02 #define HDC1080_SERIAL_ID1 0xfb #define HDC1080_SERIAL_ID2 0xfc #define HDC1080_SERIAL_ID3 0xfd #define HDC1080_ID_MANU 0xfe #define HDC1080_ID_DEV 0xff #define HDC1080_RH_RES_14 0x00 #define HDC1080_RH_RES_11 0x01 #define HDC1080_RH_RES8 0x02 #define HDC1080_T_RES_14 0x00 #define HDC1080_T_RES_11 0x01 HAL_StatusTypeDef hdc1080_read_reg(I2C_HandleTypeDef *hi2c, uint16_t delay, uint8_t reg, uint16_t *val); HAL_StatusTypeDef hdc1080_write_reg(I2C_HandleTypeDef *hi2c, uint8_t reg, uint16_t val); HAL_StatusTypeDef hdc1080_measure(I2C_HandleTypeDef *hi2c, uint8_t temp_res, uint8_t humidres, uint8_t heater, uint8_t *bat_stat, double *temperature, double *humidity); HAL_StatusTypeDef hdc1080_get_device_id(I2C_HandleTypeDef *hi2c, uint64_t *serial, uint16_t *manuf, uint16_t *device); #endif
You would need to look for another .c file #including that file
