when i try to debug in simulator mode in the keil this error is occurred.
Error: Could not load file 'C:\Keil_v5\ARM\Project\Objects\add.axf'. Debugger aborted !
what should i do?
please help me.......
1.) Press windows+R button2.)Type "regedit"3.)Go this directory "HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers"4.)If is there UV4.exe or UV5.exe than delete it. (Your keil must be closed before delete.) Than you can debug
Does the file in fact exist? If not, perhaps review the build process for errors, and fix those.
