Number of clock cycles in the execution of "SysCtlDelay" in the simulator.
In the SysCtlDelay documentation, you can read "The loop takes 3 cycles / loop."
In simulator, it takes 4 cycles / loop.
I'm wrong?
  • In the SysCtlDelay documentation
    Give a link - so that people can see exactly what you're looking at, and in context.
    How, exactly, do you determine that?
  • I am working with the Keil MDK-Lite version 5.24.2 uVision toolchain, I am working with a Stellaris® LM4F120 LaunchPad Evaluation Board from Texas Instruments. The microcontroller is tm4c123gh6pm.
    The software used is an example (Project0) supplied by Texas in Stellarisware and it is:
    int
    main(void)
        // Setup the system clock to run at 50 Mhz from PLL with crystal reference
      SysCtlClockSet(SYSCTL_SYSDIV_2_5|SYSCTL_USE_PLL|SYSCTL_XTAL_16MHZ|SYSCTL_OSC_MAIN);
        // Enable and configure the GPIO port for the LED operation.
        SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
        GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, RED_LED|BLUE_LED|GREEN_LED);
        // Loop Forever
        while(1)
            // Turn on the LED
            GPIOPinWrite(GPIO_PORTF_BASE, RED_LED|BLUE_LED|GREEN_LED, RED_LED);
    AL = 1;
            // Delay for a bit
            SysCtlDelay(2000000);
            // Turn on the LED
            GPIOPinWrite(GPIO_PORTF_BASE, RED_LED|BLUE_LED|GREEN_LED, BLUE_LED);
    AL = 0;
            // Delay for a bit
    The execution of each Delay in the simulator occupies a time of 8000000 states. Executing the Delay loop step by step, it is also observed that each loop occupies 4 states.
  • Stellarisware? That's a blast from the past!
    So have you asked Texas Instruments about this?
  • We are also using Tiva and Tivaware, but now I cannot have it.
    However, I suppose it presents the same problem
    int
    main(void)
        // Loop Forever
        while(1)
            // Turn on the LED
    AL = 1;
            // Delay for a bit
            // Turn on the LED
    AL = 0;
            // Delay for a bit
  • Again, that's TI's software - so you should be asking them about it, and/or  for clarifications on their documentation!
  • By measuring the switching time of the port with an oscilloscope, it is confirmed that Delay actually occupies 3 cycles / loop.
    And in the simulation 4 cycles / loop.
