Hi
I am working on changing the frequency of the square signal which comes from STM32F4. I used Timer and ADC simultaneously where I change ARR and CCR1 accordingly to change the frequency. When I use an incremental loop for these values I can get different frequency but When I add ADC (continuous mode) in the fly of the program, the output gives me just one frequency and when I press the reset button with changing variable resistor I get updated value. How can I solve this issue? Is there another method to do that?
this is my code:
while (1) { AA=HAL_ADC_GetValue(&hadc1);DT=0.5*AA; htim3.Instance->ARR=AA;htim3.Instance->CCR1=DT;}
-------------------------------------------------------------------------I will hear from you.
This is really nothing to do with Keil or ARM - you should be on the ST forums for this:
https://community.arm.com/developer/tools-software/tools/f/keil-forum/43684/lpc2148-timer0-not-working-as-expected/158950#158950
https://community.st.com/s/
