MDK v5.29 is installed on Windows10.
I followed the getting started tutorial. Board -> uVision Simulator -> Examples -> Copy CMSIS-RTOS2 Blinky example
The program crashed with no error message when it opened Keil uVision5.
I tried to opened it on Blinky.uvprojx file or opened Keil uVision5 at the shortcuts, but it still crashed.
i recommend to:
- download a new MDK-installer at: http://www2.keil.com/mdk5
- re-install MDK 5 to C:\Keil_V5
- compare with one of the example projects offered by the Pack Installer if the problem persists:
http://www2.keil.com/mdk5/packinstaller/
Thanks for your reply, however the MDK-installer link is where I downloaded the installer in the beginning.
I have tried to re-install it and I do save it in the path C:/Keil_V5.
I think there might be some problems in Keil uVision5.
whenever I opened Keil uVision5 by the shortcut or .uvprojx file, I could see the gui opened in a few seconds and then closed automatically without any error message.
We have been reported by some of the customers regarding this issue.Can you open the support case and we will investigate it further?http://www2.keil.com/support/silver?P=&V=&S=
