Hello All.
I have being using Keil and downloaded C51 for my 8051 developments, but now i i have downloaded MDK-ARM Software... (MDK529.EXE ), the latest version.
after installing, when i open keil, it gives me an error, IDE has stoped working. and it shuts down. can anybody please let me know, where the problem is or how can i get out of this problem.
Problem Event Name: APPCRASH Application Name: UV4.exe
I got the same problem and I solved it by switching to an old version.
what older version,
even i tried to get the older version, but i cannot see it anywhere on the keil website.
if you have, can you please provide me the link
As far as we know, v5.29 is more stable than the older versions.
What are you trying to do that is causing the crash ?
Can you help us with the instructions so that we can replicate the issue ?
For older versions, you need to have a PSN/LIC and then you can download it from below link by entering it:http://www.keil.com/download/product
initially i am downloading C51 newer version from Keil website. after installation, when i double click on Keil icon to run the software, it works perfectly,
But again when i download MDK V5.29 and install it, and when i double clip on the Keil Icon to run the software, it gives me an error, IDE has stopped working. and the program shuts down.
Have you installed both C51 and MDK in same folder ?
If yes then try to install both in separate folders and try again.
Keep in mind that uVision icon will be different for both toolchains and to open the corresponding uVision, go to the install folder of respective toolchain and open uVision from UV4 folder.
i have even tried this, but same error occurs,
have installed both in different folder, but in the same case C51 gets started but MDK version fails to start
Then open a support case and describe the issue in detail:
http://www2.keil.com/support/silver?P=&V=&S=
