hello
I write program in one kind of RTOS. But some times all the data in RAM are corrupt since I add some code
in functions, if continue add some code in the function, the data in RAM is OK.
does the data copy from FALSH to RAM by linker? I think my code has impact on linker
hello pier
I found since implement code in 0x08003E32 in function _scatterload, the data copy from Flash to RAM is not correct. I paste the code here, do you have idea about this? If I want to check the relative data in Flash, how can I know the exact data address?
0x08003E20 4C06 LDR r4,[pc,#24] ; @0x08003E3C 0x08003E22 4D07 LDR r5,[pc,#28] ; @0x08003E40 0x08003E24 E006 B 0x08003E34 0x08003E26 68E0 LDR r0,[r4,#0x0C] 0x08003E28 F0400301 ORR r3,r0,#0x01 0x08003E2C E8940007 LDM r4,{r0-r2} 0x08003E30 4798 BLX r3 0x08003E32 3410 ADDS r4,r4,#0x10 0x08003E34 42AC CMP r4,r5 0x08003E36 D3F6 BCC 0x08003E26 0x08003E38 F7FCF9C0 BL.W __main_after_scatterload (0x080001BC) 0x08003E3C 3F04 DCW 0x3F04 0x08003E3E 0800 DCW 0x0800 0x08003E40 3F24 DCW 0x3F24 0x08003E42 0800 DCW 0x0800
