we are getting UvEdit.dll error on windows 2012 server when running vectorcast for few hours , We are using keil uvison5 in simulator mode with Vectorcast.
Same setup is running fine with windows 2008 server.
Same setup is running fine with windows 10.
Please help us with the following questions :
1) Does we need any extra settings to be made for keil uvision 5 to run on windows 2012 server.
2) Any Firewall settings are causing this UvEdit.dll crash.
Further information :
If once this error is occurred, keil is crashing immiediately after relaunch. we have to restart system to fix this keil crashing.
I don't think uVision 5 is supported by Windows Server 2012. Have you tried running the executable "UV4.exe" in a compatibility mode (using a supported OS)?
