Hello folks, my first time posting on this forum so apologies if I am missing any information in this post.
I am using a STM32F746NHGx with MDK-Pro. The hardware I am working with has an 8GB SD card connected over SPI that I'm told has "never worked". I was hoping to change that but I'm unsuccessful so far.
I have found and fixed few configuration issues that may be contributing to the problem, and I've gone through the demo FileSystemComponent application, but I still get an FsMediaError when I call the fmount or fformat operations. The finit operation returns fsOK.
Here is my configuration for FS_Config_MC_0.h
#define MC0_ENABLE 1 #define MC0_MCI_DRIVER 0 #define MC0_SPI_DRIVER 2 #define MC0_SPI 1 #define MC0_CACHE_SIZE 4 #define MC0_CACHE_RELOC 0 #define MC0_CACHE_ADDR 0x7FD00000 #define MC0_NAME_CACHE_SIZE 0 #define MC0_FAT_JOURNAL 0
And what I believe are the relevant portions of RTE_Device.h (I've verified the pins match on the PCB with the correct SD card components)
#define RTE_SPI2 1 #define RTE_SPI2_MISO_PORT_ID 3 #define RTE_SPI2_MOSI_PORT_ID 4 #define RTE_SPI2_SCL_PORT_ID 3 #define RTE_SPI2_NSS_PORT_ID 4 #define RTE_SPI2_RX_DMA 0 #define RTE_SPI2_TX_DMA 0 #define RTE_SDMMC1 0
Finally, the other possibly relevant setting I have found is in FS_Config.c
#define FS_INITIAL_CDRIVE 2
My main.c (abbreviated below) is pretty simple:
#define SD_FILESYS_DRIVE "M0" int main(void) { MPU_Config(); CPU_CACHE_Enable(); osKernelInitialize(); errorMutexId = osMutexCreate(osMutex(errorMutex)); HAL_Init(); BSP_ClocksInit(); PeriphClock_Config(); digIOInit(); Init_Power_Reset(); MX_RTC_Init(); BSP_SDRAM_Init(); init_I2C(); framInit(); initNORFilesystem(); initSDFilesystem(); } int initSDFilesystem(void) fsStatus SDStatus; SDStatus=finit(SD_FILESYS_DRIVE); if (SDStatus != fsOK) { printf("SD init Failed\n"); return SD_INIT_FAILED; } SDStatus=fformat(SD_FILESYS_DRIVE, NULL); if (SDStatus != fsOK) { printf("SD init Failed\n"); return SD_INIT_FAILED; } }
All I'm hoping for is a suggestion of a configuration option I may have overlooked or some suggestions for next steps in debugging this issue. Other possibly relevant notes:
1. I'm using SPI1 successfully for other operations.
2. I can read and write successfully to the NOR flash.
3. There are no other components on the SPI bus.
4. I've tried formatting the filesystem as fat32 using a PC and then just calling fmount, but no luck.
Any advice would be greatly appreciated!
Hello Eric,
please contact technical support at support.intl@keil.com.
Kind regards,
Christopher
if everything is correct in firmware, it could still be a problem in the HW:
-check PullUp at DO line, SD-Card output is initially open-drain and requires the external pullUp until output is configured for push-pull.
-Not required but recommended: Connect a PullUp to unused data lines of SD-Card ...
Regards, Gunnar
