I'm working with B-L072Z-LRWAN1 platform and struggle to see a signal on SPI2.
My SPI2 is connected on an accelerometer. It is configured as follow:
void HW_IMU_SPI_Init( void ) { /*##-1- Configure the SPI peripheral */ /* Set the SPI parameters */ hspi2.Instance = SPI2; hspi2.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_2; hspi2.Init.Direction = SPI_DIRECTION_2LINES; hspi2.Init.Mode = SPI_MODE_MASTER; hspi2.Init.CLKPolarity = SPI_POLARITY_LOW; hspi2.Init.CLKPhase = SPI_PHASE_1EDGE; hspi2.Init.DataSize = SPI_DATASIZE_8BIT; hspi2.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE; hspi2.Init.FirstBit = SPI_FIRSTBIT_MSB; hspi2.Init.NSS = SPI_NSS_SOFT; hspi2.Init.TIMode = SPI_TIMODE_DISABLE; IMU_SPI_CLK_ENABLE(); if(HAL_SPI_Init( &hspi2) != HAL_OK) { /* Initialization Error */ Error_Handler(); } /*##-2- Configure the SPI GPIOs */ HW_IMU_SPI_IoInit( ); } void HW_IMU_SPI_IoInit( void ) { GPIO_InitTypeDef initStruct={0}; IMU_GPIO_CLK_ENABLE(); initStruct.Pin = IMU_SCLK_PIN | IMU_MISO_PIN | IMU_MOSI_PIN; initStruct.Mode =GPIO_MODE_AF_PP; initStruct.Pull =GPIO_NOPULL ; initStruct.Speed = GPIO_SPEED_HIGH; initStruct.Alternate= IMU_SPI2_AF ; HAL_GPIO_Init(GPIOB, &initStruct); initStruct.Mode = GPIO_MODE_OUTPUT_PP; initStruct.Pull = GPIO_NOPULL; HW_GPIO_Init( IMU_NSS_PORT, IMU_NSS_PIN, &initStruct ); HW_GPIO_Write ( IMU_NSS_PORT, IMU_NSS_PIN, 1 ); }
Systemclock is configured as follow:
void SystemClock_Config(void) { RCC_ClkInitTypeDef RCC_ClkInitStruct = {0}; RCC_OscInitTypeDef RCC_OscInitStruct = {0}; /* Enable HSE Oscillator and Activate PLL with HSE as source */ RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI; RCC_OscInitStruct.HSEState = RCC_HSE_OFF; RCC_OscInitStruct.HSIState = RCC_HSI_ON; RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT; RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON; RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI; RCC_OscInitStruct.PLL.PLLMUL = RCC_PLLMUL_6; RCC_OscInitStruct.PLL.PLLDIV = RCC_PLLDIV_3; if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) { Error_Handler(); } /* Set Voltage scale1 as MCU will run at 32MHz */ __HAL_RCC_PWR_CLK_ENABLE(); __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1); /* Poll VOSF bit of in PWR_CSR. Wait until it is reset to 0 */ while (__HAL_PWR_GET_FLAG(PWR_FLAG_VOS) != RESET) {}; /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2 clocks dividers */ RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2); RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK; RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1; RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1; if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK) { Error_Handler(); } }
Chip select is defined as GPIO. I can see it toggling.
I'm not quite sure what I'm missing here. Could anyone help?
Thank you
nico_g said:Could anyone help?
More likely to be found on the ST forum - as this is ST stuff, not ARM or Keil
https://community.arm.com/developer/tools-software/tools/f/keil-forum/43684/lpc2148-timer0-not-working-as-expected/158950#158950
https://community.st.com/s/
nico_g said:Chip select is defined as GPIO. I can see it toggling.
What about the other SPI lines ?
Have you tried any of ST's SPI examples to get the basics working ?
Hi Andy,
Yes I had a look on ST forum as well but couldn't find the answer. I tried different things.
Other SPI lines (PB15,PB14 and PB13) are defined as Alternate Function Push-Pull.
I even checked with code generator and had a look at what is done for SPI1 (connected to transceiver).
