Hello
I work with Tiva C Series LaunchPad, exactly EK-TM4C123GXL evaluation kit in Keil uVision. The problem is when I start a debug session, it stop immediately without any error message, and it happens with any project. Who works with the same board? Who have the same project?
The actual project is about a simple ADC reading, with CMSIS-CORE for Cortex-M and System Startup for TM4C123x Series. The code is:
#include "TM4C123.h" // Device header int result; // Variable to value of ADC conversion /* Main Function */ int main(void) { SYSCTL->RCGCGPIO |= 0x10; // Enable clock access to PORTE SYSCTL->RCGCADC |= 0x1; // Enable clock access to ADC0 GPIOE->AFSEL |= 0x8; // Set PE3 with alternative function GPIOE->DEN &= ~0x8; // Set no PF3 ditial pin GPIOE->AMSEL |= 0x8; // Set PE3 analog pin /* ADC0 Initialization */ ADC0->ACTSS &= ~0x8; // Disable SS3 ADC0->EMUX &= ~0xF000; // Software Trigger conversion in SS3 ADC0->SSMUX3 = 0; // AIN0 in sample 1, SS3 ADC0->SSCTL3 |= 0x6; // One sample, 1st last sample ADC0->ACTSS |= 0x8; // Enable SS3 /* Infite Loop */ while(true) { ADC0->PSSI |= 0x8; // Start conversion at SS3 while(!(ADC0->RIS & 0x8)); // Wait for conversion complete result = ADC0->SSFIFO3; // Value of conversion ADC0->ISC |= 0x8; // Clear flag of end conversion } }
I expect anybody have a solution.
