License error for STM32L0 free license (due 31 Jan 2020).
ARM CC notify (R203(8): EVALUATION PERIOD EXPIRED for every source file. Delete license line in TOOLS.INI is ok for compilation, but not linking (32 kB limit)
Error code
Product: MDK-ARM Cortex-M0/M0+ 256k 5.28
Component: ARM Compiler 5.06 update 6 (build 750)
Tool: ArmCC [4d3637]
compiling LPS22HB_Driver.c...
Error: C9555E: Failed to check out a license.LICENSE ERROR (R203(8): EVALUATION PERIOD EXPIRED)
Check that your license details are correct in the License Management dialog of MDK. Additional information is available at:
www.keil.com/.../license_management.htm
If you need further help, provide this complete error report to your supplier or license.support@arm.com.
- ARMLMD_LICENSE_FILE: unset
- LM_LICENSE_FILE: unset
- ARM_TOOL_VARIANT: unset
- ARM_PRODUCT_PATH: unset
- Product location: C:\Keil_v5\ARM\sw\mappings
- Toolchain location: C:\Keil_v5\ARM\ARMCC\Bin
- Selected tool variant: mdk_cm0_256k
- Checkout feature: LIC0=3A...-.....-.....
- Feature version: 5.0201709
- Keil error code: 1
Activation license
Thank you for licensing your Keil product.  Your License ID Code (LIC) is printed below.  Print a copy of this e-mail to keep for your records.
MDK-ARM Cortex-M0/M0+ 256K
For ST Only
Support Ends 31 Jan 2020
PC Description       : MY HP PROBOOK
Computer ID     (CID): CL9T1-8NMUM
