Hello
i am using cJSON keil library but i facing many problem to create object and convert object into string.
1. This code work fine
int main(void){
root = cJSON_CreateObject();
cJSON_AddNumberToObject(root, "w", 1920); cJSON_AddNumberToObject(root, "h", 1080);
//cJSON_AddNumberToObject(root, "f", 24); // This line is commented
cJSON_AddBoolToObject (root, "i",1);
char *string = cJSON_Print(root);
while (1) {
HAL_UART_Transmit(&huart3,(uint8_t *)string , strlen(string),HAL_MAX_DELAY);
HAL_Delay(500);
the above code work fine but when i uncomment the commented line (cJSON_AddNumberToObject(root, "f", 24);) , after that i did't get any value in string, i found null in string.
and also when i create two object than also i got null in both object's strings.
Can any please tell me why i am facing these problems.
Check if you have enough heap defined.
You can also debug the cJSON functions to find out where the problem is.
I have quickly tried the above code (without the HAL - just looked at the string) and I see the expected string also when enabling the line which ads number "f".
{ "w": 1920, "h": 1080, "f": 24, "i": true }
