HiI'm using the STR911 in project with Keil and ULink2 debugger. I can not set a breakpoint in C code but I can set assembly. I load my code in a microcontroller however I can not view memory map and variable.
This is debug setting in my project.
http://www.keil.com/support/docs/3902.htm
Although I'm doing this instruction but not working.
This is all really ancient stuff - is there a particular reason for that?
masnmz said:I can not set a breakpoint in C code but I can set assembly
Did you enable Debug Information in your compiler settings?
masnmz said:This is debug setting in my project
Sorry - your picture is too small to see what settings you have there!
