Hi
I am writing bare-metal code for PWM generation for the FRDM-KL25Z board.I followed the steps in the datasheet bit I dont seem to see anything coming from the pin. Would appreciate some help to see what I am missing.
#include "MKL25Z4.h" // Device header /* PTB18 -> TM2 CH0 PTB19 -> TM2 CH1 */ #define PTB18_Pin 18 #define PTB19_Pin 19 #define PTB18_PWM_Ch 0 #define PTB19_PWM_CH 1 #define MASK(x) (1 << (x)) /* intiPWM() */ void initPWM(void) { //Enable Clock Gating for PORTB SIM_SCGC5 |= SIM_SCGC5_PORTB_MASK; // Configure Mode 3 for the PWM pin operation PORTB->PCR[PTB18_Pin] &= ~PORT_PCR_MUX_MASK; PORTB->PCR[PTB18_Pin] |= PORT_PCR_MUX(3); PORTB->PCR[PTB19_Pin] &= ~PORT_PCR_MUX_MASK; PORTB->PCR[PTB19_Pin] |= PORT_PCR_MUX(3); // Enable Clock Gating for Timer2 SIM->SCGC6 |= SIM_SCGC6_TPM2_MASK; // Select clock for TPM module SIM->SOPT2 &= ~SIM_SOPT2_TPMSRC_MASK; SIM->SOPT2 |= SIM_SOPT2_TPMSRC(1); // MCGFLLCLK or MCGPLLCLK/2 SIM->SOPT2 &= ~SIM_SOPT2_PLLFLLSEL_MASK; SIM->SOPT2 |= SIM_SOPT2_PLLFLLSEL(0); // MCGFLLCLK // Set Modulo Value 48000000 / 128 = 375000 / 7500 = 50 Hz TPM2->MOD = 7500; // Update SnC register: CPWMS=1, CMOD = 01, PS=111 (128) TPM2->SC &= ~((TPM_SC_CPWMS_MASK) | (TPM_SC_CMOD_MASK) | (TPM_SC_PS_MASK)); TPM2->SC |= (TPM_SC_CPWMS(2) | TPM_SC_CMOD(1) | TPM_SC_PS(128)); TPM2_C0SC &= ~((TPM_CnSC_ELSB_MASK) | (TPM_CnSC_ELSA_MASK)); TPM2_C0SC |= (TPM_CnSC_ELSB(1)); } /* MAIN function */ int main(void) { SystemCoreClockUpdate(); initPWM(); TPM2_C0V = 0x8000; while(1) {} }
Thanks!
This really has nothing to do with Keil or ARM - you need the NXP forums for specific questions about the operation of NXP chips & their peripherals:
https://community.nxp.com/
https://www.nxp.com/design/engineering-services:SW-SUPPORT
See: https://community.arm.com/developer/tools-software/tools/f/keil-forum/43684/lpc2148-timer0-not-working-as-expected/158950#158950
