In my project I'd like to have Ethernet and Wifi support at the same time.
In order to evaluate the possibility to use the MDK5 for my project, I tried to configure my project by means the Keil uVision IDE adding Ethernet and WiFi interface.
The problem is that it seems not possible to set Ethernet and WiFi Interface at the same time.
The two components Network:Interface:ETH and Network:Interface:WiFi are not compatible.
Could someone help me to understand if I miss something in project configuration or it is not possible to have Ethernet and also WiFi support?
Thanks,
Giovanni.
Thanks a lot!!
Giovanni
